2000 gsr over reved
Old Feb 2, 2011 | 11:54 AM
jehcee_dc2's Avatar
Default 2000 gsr over reved
hello honda tech...the other day i was racing my friend and when i was on 3rd instead of putting into 4th i threw in to 2nd and over reved it..now my car is telling me theres a misfire on cylinder 2 and 4..what do i do???
-someone told me to change the distributor?
Old Feb 2, 2011 | 12:14 PM
racebum's Avatar
Default Re: 2000 gsr over reved
what happend? my wild *** guess is bent valves. start with a compression test, if that checks we'll go from there. make sure you disconnect your distributor before you do a compression test.
Old Feb 2, 2011 | 01:27 PM
1998GsRIntegra's Avatar
A compression test is definitly needed. How over revved was it? Way off the tach or what?
Old Feb 2, 2011 | 04:25 PM
jehcee_dc2's Avatar
yea i super redlined:/ do you know the compression level for the cylinders
i have the compression tester.
Old Feb 2, 2011 | 04:35 PM
dntnedvtec's Avatar
don't street race....Now your car is broken.
Old Feb 2, 2011 | 04:57 PM
racebum's Avatar
doesn't even matter if you do it cold, you're looking for the numbers being out of wack. 180ish is normal warm, cold it's less. if you see one cylinder 50psi down or more you have problems.
Old Feb 2, 2011 | 05:29 PM
jehcee_dc2's Avatar
okay thanks for the info..ill give it a test tomorow.
Old Feb 3, 2011 | 01:59 PM
BeantownBeatdow's Avatar
Yeah, but we've all done it. He just wants help.
I've done this twice without any damage. THE MONEY SHIFT.
Old Feb 3, 2011 | 02:59 PM
danielblushtein's Avatar
you lucky-duck. I did it and redlined @ 9k or so. After that it sounded sorta like a subaru at idle. 3rd cyl had low comp. Luckly this was during winter break and I had the time to fix/rebuild my motor.
A dude I raced did the same thing and his 3rd cyl had ZERO comp.
Nevertheless honda's are easy/fun/and cheap to rebuild. I learned a lot.
Old Feb 3, 2011 | 05:02 PM
If you never break anything you will never learn how to fix it.
Old Feb 3, 2011 | 06:07 PM
N/A's Avatar
N/A
Purpose Built
Hey paul walker, learn to drive before you race.
Old Feb 3, 2011 | 06:25 PM
hatmanafro's Avatar
Lmao!^
Sucks for the OP tho. Did he ever do the compression test?
Old Feb 3, 2011 | 07:24 PM
mapa1229's Avatar
did that once but more worse, missed third and went into 1st!! horrible!!
Old Feb 3, 2011 | 07:36 PM
N/A's Avatar
N/A
Purpose Built
Your trans shouldn't have been able to do that, your trans is probly ****ed also
Old Feb 4, 2011 | 03:21 PM
dntnedvtec's Avatar
? The tranny should have locked you out of going into first.
OP, needs compression numbers asap...
Old Feb 4, 2011 | 03:24 PM
happyc4mp3r's Avatar
im sure they will have some of us err you people that money shift
http://www.nexternal.com/uuc/article..._technique.htm
Old Feb 4, 2011 | 03:45 PM
Dogginator's Avatar
Daisy... Daisy...
You pull the head and replace the bent exhaust valves. If you are 96+, pull the codes. Expect to see 71, 72, 73, or 74.
Old Feb 4, 2011 | 03:59 PM
N/A's Avatar
N/A
Purpose Built
OP, needs driving lessons asap...
Fixed
Old Feb 4, 2011 | 05:46 PM
hatmanafro's Avatar
damn. im gonna have to try that.
Old Feb 4, 2011 | 06:46 PM
dc2LS's Avatar
I sure am glad this has never happende to me .stop granny shifting and start double clutching like you should
just kidding make sure you do the compression check as mentioned above.You might have bent valves
Old Feb 4, 2011 | 06:49 PM
kaiba's Avatar
Was it.....
OVER 9000!!!
Old Feb 4, 2011 | 07:02 PM
careawholelot's Avatar
never done it. had bros that did, bent valves were the outcome
Old Feb 4, 2011 | 07:04 PM
dntnedvtec's Avatar
Originally Posted by N/A
Fixed
thanks, I meant that too...
Old Feb 5, 2011 | 04:18 AM
N/A's Avatar
N/A
Purpose Built
Lol I'm waiting for one of the village idiots to come in and say he'll be fine cause they "rev to 10k on the street poppin mad vtec yO!"
Old Feb 5, 2011 | 05:11 AM
OC_DC2_JDM>EURO's Avatar
same thing happened to me, bent about three valves lol, rebuilt the head and presto! gsr was running meaner then ever ..and if you rebuild the head...get dual vavle springs, will help incase it happens again.
Brandon Peters
Oct 18, 2015 05:37 PM
boosted_lude
Jan 27, 2006 09:31 AM
93H22ACX
Jul 15, 2004 02:33 AM
Audipwr1
Nov 16, 2001 08:42 PM
