1994 Accord reverse
Got a problem. Evry time I put the key in the ignition switch I get of my car and see my reverse lights are on. Every time I put the key in the switch it does that. Do the reverse lights have a fuse o relay or something like that? Any help would be apreciated. Thanks.
Auto or stick....either way, check the switch....two pin switch on the trans somewhere (? its late) near the starter. There should only be continuity between the two terminals when the trans is in reverse....of course check the wires at the switch to be sure they are ok.
sam786
Jan 1, 2010 10:53 AM
Redicliff@honda-tech
Nov 28, 2004 06:44 AM
