ef9 radiator hose help
Old Feb 2, 2011 | 06:09 AM
TURKISHFORCE's Avatar
Default ef9 radiator hose help
hello
my top radiator hose draws pressed squeeze together like a sandwich if motor is cold and cooled?
in normal drive without boost are the radiator hose quite strong hard.??
i have change thermostat, water,pump, cooler cover,vented the air systeme?
maybe gasket is litle broke?
compression test result is 9 bar
no blue ore white smoke,no consumption
but expansion water tank is always empty and a litle bit
öl lubrication is in the radiator cap cover on the top.
someone infos.
Old Feb 2, 2011 | 07:48 AM
mouab18c1's Avatar
Default Re: ef9 radiator hose help
Keep bleeding your coolant system. You have air pockets still.
JibOnALib
Dec 21, 2004 09:09 AM
prplecivic94
14
Jul 15, 2004 05:26 AM
pnltnc
Mar 30, 2004 06:30 PM
oMek
Feb 4, 2004 06:55 PM
