Enkei Metal Valve Stem Install
Old Feb 1, 2011 | 07:22 PM
fernando.'s Avatar
Default Enkei Metal Valve Stem Install
Recently purchased some new RPF1's and they came with the supplied metal vavle stems. Are these good to use, or would the rubber ones be better? Also, is there a torque spec to tighten the nut on the stem?
Old Feb 1, 2011 | 07:59 PM
randomtask77's Avatar
Default Re: Enkei Metal Valve Stem Install
I would use the included valve stems.
If not, then every time you get new tires, they have to replace the stems and most of the time, they just rip those out and might cause damage to the wheels.
Old Feb 2, 2011 | 05:06 AM
fernando.'s Avatar
Ok, thanks. Is there a torque spec for the nut?
Old Feb 2, 2011 | 09:32 PM
torontoefsedan's Avatar
PFT - pretty ****in tight. I've never had any leak just make them tight but not stupid tight.
mortificationrock
27
Sep 7, 2010 01:10 PM
8OOSTED
Sep 22, 2009 10:18 AM
all-mtr-teg
Jun 12, 2007 04:43 PM
Willard
Aug 17, 2006 12:26 PM
nighttime
May 24, 2002 09:23 PM
