negative camber help!!
Old Feb 1, 2011 | 04:54 PM
EG6Marcus's Avatar
Default negative camber help!!
i have 10mm offset dr20's and my eg doesnt sit as low as i would like due to tires scraping when its too low, can i just buy camber kits and go for some negative camber so i can lower it or would i also need spacers or studs( im not going for a hellaflush look, just trying to lower a bit more)
Old Feb 1, 2011 | 05:46 PM
TheAsian's Avatar
Default Re: negative camber help!!
Why do you want to dump it lower.
Depending on how low you are you should just go get a alignment.
Read the thread you don't need camber kits, there is a lot of good us full info in there. That I support myself through what I have seen lowering and aligning my own car.
Old Feb 1, 2011 | 10:13 PM
toyomatt84's Avatar
Sanji
This forum is not the place for "hellaflush" setups. Considering the unsafe nature of that style, I would advise against the look for any car that is driven on a continual basis.
diznikkajebus
28
Apr 2, 2009 04:42 PM
joostan
Dec 7, 2005 05:08 AM
jda90
Suspension & Brakes
Aug 19, 2005 10:33 AM
kndaqikEG
Feb 20, 2005 05:42 PM
Ludeboi
Sep 23, 2003 08:36 PM
