HELP: Left Headlight Front Turn Signal
Old Feb 1, 2011 | 04:44 PM
kd SOO JDM's Avatar
Default HELP: Left Headlight Front Turn Signal
I have a small problem....It seems that my Left Headlight Front Turn Signal does not light up whatsoever, almost as if its just a dead bulb. But i did change the bulb and still nothing... Soo i need help any suggestions would be appreciated!
Some questions i have for anybody who can answer them.
1. Does this have something to do with the ground wire ?
2. Are the wires in their appropriate plugs ?
Brand New Bulb..
Picture of the ground..
Do you think this small cut on red/black wire is the problem?
or
Are these wires in their appropriate holes ?
Please help me guys
Old Feb 1, 2011 | 04:45 PM
kd SOO JDM's Avatar
Default Re: HELP: Left Headlight Front Turn Signal
By the way.. the car is a 1997 Civic Ex
Old Feb 1, 2011 | 05:17 PM
TheAsian's Avatar
Are you any good with a multimeter or a test light? For sure that nic in the wire can cause built up resistance from corosion and the circuit will fail. I would check power and grounds at the connector.
Old Feb 2, 2011 | 12:16 PM
kd SOO JDM's Avatar
Nope, i dont even know what a multimeter and/or a test light is.
And should i solder up that nic or something ? Or should i cut it and splice it back together ?
And how would I check power and grounds at the connector ?
Sorry i'm new to all of this.
Old Feb 2, 2011 | 04:45 PM
fcm's Avatar
fcm
Old Fart
You can get a multimeter at Radio Shack for about $30, you can get a 12V test light for under $4 at just about any car parts store.
The plug is not the headlight.
Left head light colors are red/green (low) red/yellow (high) black is ground for both.
Right head light colors are red/white (low) red/blue (high] black is ground for both.
Use a testlight or meter to check for power and ground on the leads at the plug.
The plug in the pic is the left front park turn signal...
Red/black is park light and green/red is turn signal, black is ground for both.
Use a meter or test light on them also. 94
joeym415
Lighting
Nov 8, 2007 01:03 PM
EM2Thrasher
Honda Civic (2001 - 2005)
May 10, 2006 06:29 PM
Skank_aSS_Dara
Aug 23, 2004 11:52 PM
ebp 99 si
13
Jun 3, 2004 11:20 AM
JDMlyfestyle
Dec 2, 2003 08:25 PM
