Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Clickin' N Knockin'
Old Feb 1, 2011 | 03:24 PM
memphisrains's Avatar
Default Clickin' N Knockin'
08 Civic EX Coupe Automatic, 50K, Certified Used Car from Honda dealer.
I have had this vehicle about 2 months and have noticed two noises that are aggravating and alarming. The aggravating noise sounds as if it is a lifter clicking....I hear it when I am at idle. It sounds like a light tapping and sometimes goes away. I can't hear it while moving.
The second noise...the alarming one....sounds almost as if it is a rod bearing or piston pin. On light and constant acceleration under a light load I can hear the noise. Could this be some emission or exhaust noise?
Anyway I am getting it back to the dealer next week and I wanted to get some opinions from you guys and guyettes. Thanks in advance.
Note: I'm driving my pickup until I find out what's up with the noise.
Old Feb 23, 2011 | 10:14 PM
trex91's Avatar
Default Re: Clickin' N Knockin'
Have you found anything out from hte dealer about the noise? I have a similar issue and I don't want to spend to much money fixing the car up and then have a spun rod bearing.
Old Feb 24, 2011 | 02:45 PM
pd0019's Avatar
first noise is injectors, wouldnt worry about it.
dont know about your second noise.
Old Feb 24, 2011 | 06:41 PM
wildabeast's Avatar
can you get a camera or microphone and record the noise?
Old Apr 11, 2011 | 12:55 PM
trex91's Avatar
The sound could be from the timing belt tensioner. One of my mechanic buddies told me to pray soapy water on the belts for any belt noise. I put a long screw driver to hear where that rattling noise is from and I can't figure it out. I tried adjusting the valves but no change. The sound is more erratic and not harmonious with the motor. Is the piston pin noise a rattling noise?
kenskii
Jul 8, 2014 08:33 PM
memphisrains
Feb 7, 2011 03:10 PM
Touge Tuning
Jul 4, 2006 09:13 AM
Nicknyce
Jan 16, 2005 10:20 PM
ef_you
Dec 25, 2004 09:41 PM
