guages,clock,blinkers dont work after motor swap
Old Jan 31, 2011 | 01:17 PM
NAkid's Avatar
Default guages,clock,blinkers dont work after motor swap
Ok so I did a have 94 cx hatch, I installed a z6 motor this past weekend, and none of my guages, clock, or blinkers work now. Everything worked before the swap. Car runs fine. Any help would be appreciated thanks.
Old Jan 31, 2011 | 01:18 PM
Former User's Avatar
Default Re: guages,clock,blinkers dont work after motor swap
Blown fuse 15.
Old Jan 31, 2011 | 01:23 PM
NAkid's Avatar
I have checked all my fuses multiple times. There all good.
Old Jan 31, 2011 | 01:24 PM
NAkid's Avatar
My dash lights work, andsome info lights on the cluster turn on, just the guages don't work.
Old Jan 31, 2011 | 01:25 PM
Check again. Use a test light to check 10A dash fuse 15. With the key in ON(II), there should be voltage to body ground on both top test tabs.
People miss blown fuses all day long on this forum.
Old Jan 31, 2011 | 01:29 PM
NAkid's Avatar
Alright theni will check them again with a test light and let you know what happens.
Old Jan 31, 2011 | 01:31 PM
For now, just check 10A dash fuse #15. It's more than likely blown.
pang_yeng
21
Nov 24, 2011 05:52 AM
el lucas
Oct 9, 2010 02:28 PM
lokoo23
20
Sep 12, 2009 08:15 AM
Linh.
Dec 6, 2005 04:14 PM
GdmLaz
13
Sep 11, 2005 12:53 AM
