Performance General Performance oriented Parts (Ex: Camshafts, Electronics, Air Intakes, Exhausts, complete engines)
****AEM UEGO Special....Get an Extra 5% Off!!!****
Old Jan 31, 2011 | 12:54 PM
UpNextCarParts's Avatar
Default ****AEM UEGO Special....Get an Extra 5% Off!!!****
What's up everyone!
We're running an awesome special on AEM's UEGO Wideband gauge (PN: 30-4100). Check it out at our site: http://www.upnextcarparts.com/p-1153...ego-gauge.aspx
When checking out, enter the coupon code: UPNEXTUEGO and receive an addition 5% off your AEM UEGO.
A wideband UEGO sensor controller accurately monitors Air/Fuel ratios (AFR) during the tuning process to prevent a lean fuel mixture, which could lead to engine damage. AEM has combined its single-channel wideband UEGO controller and gauge display into one unit, uniting unsurpassed AFR accuracy and control with an easy-to-read interface. AEMs Gauge-Type Wideband UEGO Controller features a digital LED display and sweeping LED needle that changes colors as AFR changes from rich to lean. The units 52mm (2-1/16) gauge housing fits in most gauge pods and can be remotely mounted virtually anywhere.
• Ideal AFR monitoring tool for EFI and carbureted applications, and engine dynamometers
• Does not oscillate AFR reading like narrow band sensors
• No laptop required for monitoring!
• Bosch sensor included
• Accurate to 0.1 AFR
• Reads in AFR or Lambda via a switch in back of gauge housing
• 24 Color-coded LED display lights provide immediate reference to engines air/fuel ratio (AFR) or Lambda ratio
• Integrated three-digit display reveals AFR or Lambda in real time
• User-programmable 0-5v analog output included for use with data loggers and virtually any engine management system
• Serial data stream included for output of AFR (RS 232)
Old Feb 1, 2011 | 02:18 PM
Default Re: ****AEM UEGO Special....Get an Extra 5% Off!!!****
TTT
Old Feb 2, 2011 | 08:03 AM
Good Morning! Get these while supplies last.
Old Feb 2, 2011 | 11:57 AM
Lunch time bump!
Old Feb 3, 2011 | 08:56 AM
Good morning
Old Feb 4, 2011 | 08:33 AM
Morning bump. If you guys have any group buy or sales suggestions, PM and I'll see what i can do.
Old Feb 4, 2011 | 01:37 PM
Afternoon Bump
Old Feb 8, 2011 | 08:35 AM
Bump!
Old Feb 14, 2011 | 10:19 AM
Morning Bump!
phearable
Jan 9, 2008 03:23 AM
phearable
74
Oct 16, 2007 05:33 PM
mtber
26
Jul 20, 2007 09:49 PM
mtber
Jul 18, 2007 04:09 PM
