H22A4 swap into a 6th gen accord wiring question.
Old Jan 31, 2011 | 11:51 AM
BrothaSit's Avatar
Default H22A4 swap into a 6th gen accord wiring question.
alright i just got the car started wired all the wires that are on the stock accord engine harness. every sensor is correctly plugged in except one which is the one wire temp plug that is under the distributor. do i have to wire this straight to the cluster or just leave it alone? the stock f23 motor didnt have one and there are no extra wires or plugs on the engine harness. i also want to note that i didnt even wire the tach signal wire (blue wire from the distributor) and the tach works. the ecu im running is a chipped p28.
Old Jan 31, 2011 | 07:40 PM
BrothaSit's Avatar
Default Re: H22A4 swap into a 6th gen accord wiring question.
wow really? i know someone has this answer on ht.
Old Jan 31, 2011 | 10:04 PM
20-EM2-05's Avatar
Don't expect a fast response for that question on H-T especially on the accord forums. For faster direct response you could check out 6thgenaccord (I use that more often now since i'm a 6thgen owner).
I would say you should leave leftover wires alone and make sure it's not exposed to any other wire touching.
Does the car run fine? If so, then I believe your car doesn't need to be messed with anymore hah.
Old Feb 1, 2011 | 09:53 AM
BrothaSit's Avatar
yea it runs fine no engine check light so i guess thats a good thing lol
DannyBoy310
Apr 3, 2012 07:17 PM
PhrequenC
Aug 10, 2008 11:06 AM
serious
Jan 19, 2003 02:42 PM
JoKeSduH
Audio / Security / Video
Nov 28, 2002 09:08 PM
