blowing fse 14
Old Jan 30, 2011 | 09:59 PM
killa69er's Avatar
Default blowing fse 14
blew fuse 14 when getting on the highway..
90 civic zc single slam swap..
fuse 14 at alldata says "gauge assembly, engine sensors and controls"...
where would bew a good place to look for a problem?
i have been going thought the wiring and havent found and drounds out wires yet..
no check engine lights, car runs great untill the fuse pops then it will not run..
i think the fuse also runs the ecm.. pop in a new fuse and fires right up..
i need to fixed this asap... any help? im kinda thinking voltage reg?? since both time this has happened when getting on the highway and punching the gas..
maybe its overloading it and blowing the fuse..
i have this but me and wiring suck... andout willing to help wire tuck the car the right way and help look over this wiring?
shoot me a price
Old Jan 31, 2011 | 12:59 PM
killa69er's Avatar
Default Re: blowing fse 14
anyone?
Old Feb 1, 2011 | 06:14 PM
killa69er's Avatar
44 views and not help yet??
Old Feb 2, 2011 | 07:00 AM
Jaime 91SiB18's Avatar
All I can tell you is something on that circuit is shorting, or pulling more amps than rated causing your fuse to blow.
Start checking individual components on that circuit as well as all the wiring.
If you can, unplug some unnecessary items and see if it still happens.
Process of elimination, if possible....
allenlavoie
Apr 23, 2012 03:34 AM
XRacerX
Sep 9, 2009 08:50 AM
John F
Aug 21, 2005 08:14 AM
GreenD16Y8
Aug 8, 2005 03:59 PM
Tuesdaynightfever
Apr 5, 2005 07:34 PM
