EJ6 - front brake rotor split
Old Jan 30, 2011 | 08:40 PM
D Griff's Avatar
Default EJ6 - front brake rotor split
Hey guys, I have a 1997 DX coupe, pretty stock with 160k miles on it. I was having some weird brake problems driving to and from work last night, and checked it out today and the rotor split right where the part with four holes that go on the wheel studs meets the bigger, actual brake disc part. Has this ever happened to anyone? What may have caused it? Just rust and old age I guess.
Anyway, I ordered some Brembo blanks and Hawk HPS pads today to put on the car. My question is, will the pads come with the little bracket pieces that mount the disc to the caliper? Should I buy these from Honda? Thanks!
Old Jan 31, 2011 | 07:31 PM
D Griff's Avatar
Default Re: EJ6 - front brake rotor split
Bump, does anyone know if my hawk hps pads will come with the little brackets that hold them to the calipers?
Old Jan 31, 2011 | 07:33 PM
94EG8's Avatar
Seagull Management
What little brackets? Pads normally come with shims if that's what you mean, or are you talking about the anti-rattle clips the pads slide in? In that case no.
Old Jan 31, 2011 | 07:40 PM
D Griff's Avatar
Yeah, I knew they come with shims, I meant the clips. One of mine fell off when the brakes got all jacked up. Maybe they'll have them at my local stealership.
Old Jan 31, 2011 | 07:42 PM
94EG8's Avatar
Seagull Management
You can buy them there, you can get them aftermarket too for a lot less at an autoparts store as a kit (I've bought them before, was like $25 for the aftermarket kit for both front brakes, came from raybestos, fitment was good)
Old Jan 31, 2011 | 07:43 PM
D Griff's Avatar
Oh, awesome. Thank you!
Tenzo
Suspension & Brakes
May 13, 2012 11:03 AM
antig24
Aug 13, 2011 07:43 AM
Uncle Ben's
Suspension & Brakes
Mar 27, 2009 01:07 AM
h8ted ek
Aug 26, 2008 04:18 AM
acuraLSSE95
Jul 28, 2003 06:39 AM
