Power Steering Noise? help me
Old Jan 30, 2011 | 07:55 PM
sky9's Avatar
Default Power Steering Noise? help me
Car. 6th gen 2000 Accord lx 4cly 5speed. 90k
soo their is a noise that happens when i make a U-turn or hard turn with the car. its like a groaning noise/whining. The noise only happens when i make sharp turns or U-turns while on the accelerator.
does any only have any ideas?
Old Jan 30, 2011 | 08:01 PM
the white sam's Avatar
Default Re: Power Steering Noise? help me
1. it could be a bad power steering pump
2 a bad power steering hose about to blow
3 or u might have to check your power steering fluid
and if u do put more power steering fluid make sure u use, HONDA power steering fluid in, i didnt put the right kind in that, and two days later, the hose blew.
Old Jan 31, 2011 | 06:28 AM
nus_dogg's Avatar
Flush the system with some new Honda ones; otherwise, I'd just get a new pump if that doesn't fix it.
Old Jan 31, 2011 | 01:16 PM
sky9's Avatar
thnx i appreciate the feedback.
Old Feb 23, 2011 | 05:55 PM
sky9's Avatar
ok i just flushed my power steering fluid with OEM honda fluid.
the noise is still their, again the noise is rubing/whining/groning noise that only happens when i make hard turns or u-turn while apply the gas pedal.
if i make hard turns or u-turn in neutral the car doesnt make any noise.
should i replace my power steering pump?
Old Feb 23, 2011 | 06:30 PM
phootbag's Avatar
No. You need further diagnostics. Great job determining the noise doesn't happen when in neutral. That is very important.
Cars can make a TON of different noises. Describing the noise through text is no substitute for actually being able to hear the noise ourselves. It's like describing the color orange to a blind person.
Try changing your transmission fluid.
Old Feb 23, 2011 | 07:47 PM
sky9's Avatar
ill try to do my transmission fluid this weekend, since i was planing on doing it anyways. i hope this helps.
man oem honda fluid dont come cheap.
Old Feb 24, 2011 | 06:58 AM
CRZ1's Avatar
power steering was $2 a bottle, now it is $4 a bottle. That is the price for the confidence, the stuff you pour into your car is right.
Old Feb 24, 2011 | 01:30 PM
rival12's Avatar
Icon6 Re: Power Steering Noise? help me
Are you talking Squeel? like Ball Joint Squeel when you turn?
If that's the case gets those changed asap, or you Wheel will separate and you may slide into your death.
Have you looked at the suspension components?
Tie-Rod?
Ball Joints?
Bushings?
Shocks?
Springs?
Wheel Bearings?
If the Power Steering is the issue, you should hear noise when you turn (every turn). That pump is always under pressure when you turn......
Old Feb 24, 2011 | 05:32 PM
phootbag's Avatar
Tie-Rod?
Ball Joints?
Bushings?
Shocks?
Springs?
Wheel Bearings?
It was stated the noise only occurs when accelerating through a turn. In neutral, there is no noise. Everything you suggested is likely not the cause.
Old Feb 24, 2011 | 09:54 PM
rival12's Avatar
Still could be suspension components. My Balljoints when they needed changing only made noise under acceleration through a turn.
Phootbag, are you a mechanic?
Old Feb 25, 2011 | 02:40 PM
phootbag's Avatar
Nope. Actually I don't really know much about cars.
ITR184
Apr 16, 2020 07:51 AM
CheezeFrog
Nov 18, 2019 11:11 PM
questseek
Mar 6, 2010 09:32 PM
Inextricabledrvr
Mar 18, 2009 07:56 PM
Elvis1977
Dec 16, 2003 07:46 PM
