Transmission & Drivetrain Gearboxes, Differentials, Clutches
96 GSR will not engage gears Help!
Old Jan 30, 2011 | 07:11 PM
Lemmingz's Avatar
Default 96 GSR will not engage gears Help!
Hey I have a 96 GSR motor mated to a B16B Transmission, the other day I was driving home and the car made a light popping sound and would not engage any gears. I could physically shift the car into the gear but I would not get any power to the wheels... it would just rev like it was in neutral. So I figured it was the clutch/pressure plate, I just finished swapping those parts out tonight. Everything looked good when I took the old parts out, except for an axle which was broken inside the cv boot. I went to test drive it and everything was going fine until I heard that popping sound again and It's back to square one... It will not engage gears again >< Any help would be greatly appreciated.
Thanks
Old Jan 31, 2011 | 06:30 AM
TheAsian's Avatar
Default Re: 96 GSR will not engage gears Help!
First thing. Would check is your axle. Make sure it is still seated in the transmission.
Old Feb 2, 2011 | 03:58 PM
JJsMotorsports's Avatar
x2
Old Feb 2, 2011 | 06:39 PM
Lemmingz's Avatar
So I was able to work on it yesterday and checked out the passenger side axle, it appears the one that the dealer sold me was about a cm and a half shorter then the original and all the teeth on the front side of the lock right had been chewed off ><. Trying to get a new one in atm.
b18c1vtecdc2
Feb 13, 2017 10:42 AM
96 acura
Oct 10, 2013 09:04 AM
cagedGSR
Mar 30, 2012 06:50 PM
Lemmingz
Jan 31, 2011 05:50 PM
