OBD0 to OBD1 issue, could use help.
Old Jan 30, 2011 | 06:57 PM
lingo104's Avatar
Default OBD0 to OBD1 issue, could use help.
Hey I got an amazing deal on a crx and pretty much jumped on it. Its an 88 HF with a b20v in it. I got the good deal due to the fact that the previous owner was having issues, and no longer had the time or money for the project. He also needed money for other things in life. Now I know the motor is good, cause he got the motor from a very close friend of mine not to long ago.
Now onto the issue at hand. The owner before the last converted the car from obd0 to obd1 and did a pretty hack job at that. So when doing the swap the last owner also swapped in an si engine harness. The car starts and runs fine but wont rev past 3500... My understanding of that its running in limp mode. Both the ecu and distributor are obd1, several different distributors and ecu's were used with no luck.
I checked the cel and am getting a code 4.
Any help would be appreciated.
Old Jan 30, 2011 | 07:02 PM
8dxhatchy8's Avatar
Default Re: OBD0 to OBD1 issue, could use help.
i believe code 4 is the crank angle sensor..correct me if im wrong but thats a dizzy wiring problem, check all the wires at the dizzy and make sure there right..
Old Jan 30, 2011 | 07:36 PM
efjones9's Avatar
Yupp sounds like a wiring issue. Trace the wires back to the ecu
Old Jan 31, 2011 | 12:19 AM
EF_NITROUS_FEED's Avatar
look up the pin out for a obd1 ecu and find the crank angle wire and make sure its all good
Old Jan 31, 2011 | 01:09 AM
hatchet_honda's Avatar
ugghhh...good motor BAD wiring job. i hate those! ppl are idiots! who uses speaker wire on the battery?!..sorry for the rant. def check the dizzy wiring. perhaps the 2 white wires are mixed
Old Jan 31, 2011 | 08:14 AM
stackedhouse's Avatar
i had same problem could be wiring but mine had actually jumped a tooth on the intake cam.. check your timing too
Old Jan 31, 2011 | 08:27 AM
K&NGEO's Avatar
yep, wiring at the distributor is possibly incorrect
Old Jan 31, 2011 | 01:19 PM
tonythetuner®'s Avatar
Check my sig for the proper. Pin outs for the obd1 dizzy plug make sure the wires are in the right location
Old Jan 31, 2011 | 01:22 PM
lingo104's Avatar
Thanks guys... Ill be checking that stuff tonight when i get home. Always wanted a crx, and now this is how im introduced to them lmao.
Old Jan 31, 2011 | 03:06 PM
8dxhatchy8's Avatar
its not the car its the retarded previous owner who molested it, that screwed it up.
Old Jan 31, 2011 | 03:27 PM
lingo104's Avatar
Yea i dont know who to blame... The 1st owner who did the really bad hackjob, cause i got to see that before the newer owner attempted to fix it with the si harness.
Old Jan 31, 2011 | 03:38 PM
dc2_dustin!'s Avatar
hope this helps..my ef came with the same issue and i had to repin most of the passenger harness
http://www.phearable.net/tech/wiring...schematics.gif
CRXguy_88
Jul 2, 2010 04:30 PM
B18Cej1
Mar 29, 2008 10:49 PM
nelsonb16
Jan 31, 2008 06:41 PM
Dr. D-Series
Oct 29, 2007 08:53 AM
ivanson
Dec 4, 2005 12:35 PM
