will driving without power steering pump mess anything up?
Old Jan 30, 2011 | 10:19 AM
rolledthatho's Avatar
Default will driving without power steering pump mess anything up?
hey guys pretty simple questions im not very well veresed in power steering and i know a lot of the civics come without it but they have (i believe) manual racks. if my car was set up for power steering and i took the pump off will that harm anything in the long run?
Old Jan 30, 2011 | 03:56 PM
Default Re: will driving without power steering pump mess anything up?
bump
Old Feb 9, 2011 | 05:34 PM
Destructive-'s Avatar
my power steering pump recently went out, so i removed the belt, and about 2 weeks later i got leaks coming from the power steering rack. I'm not saying this was the cause of it, but i would really like to get an answer to this question as well as i thought about the same thing. BUMP
Old Feb 9, 2011 | 05:38 PM
alex14's Avatar
I ran mine without the belt connected for a few days and it made my PS tank leak all over my shock tower. I think over time it wears the parts out faster.
Old Feb 9, 2011 | 06:03 PM
Ken99287's Avatar
... did you guys feel a power increase without the ps belt? just curious
Old Feb 9, 2011 | 08:11 PM
theft24's Avatar
no it will not harm your rack, just drain all the fluid out of it and take the lines and tank off
Old Feb 10, 2011 | 12:22 AM
hatchet_honda's Avatar
plus itll be harder to steer. youll have to be turning not only the wheels but youll be manually moving the pistons inside the rack back and forth instead of the hydro power doing it for you
Old Feb 10, 2011 | 07:14 PM
theft24's Avatar
theres hardly a difference
Old Feb 10, 2011 | 08:20 PM
alex14's Avatar
You have absolutely lost your mind.
Old Feb 11, 2011 | 07:45 AM
theft24's Avatar
no i just havent drove a car with power steering in the past 6 years
Old Feb 11, 2011 | 07:51 AM
alex14's Avatar
Taking a car with power steering, and taking the belt/pump off makes it a bitch to drive at low speeds.
driving a car with a manual rack and pinion is TOTALLY different than a PS rack with no PS pump.
Old Feb 11, 2011 | 08:33 AM
night's Avatar
that is gearing
Old Feb 11, 2011 | 11:27 PM
89LSED's Avatar
I have never had power steering with my Wagon.
It is a power rack with everything taken of it.
My buddy looped his power steering lines to keep a bit of fluid in it and his is alot easier to steer than mine... but he also has a DA with 17"s
Old Feb 12, 2011 | 06:13 AM
KINGVEM^^ED6's Avatar
put the pump back on
at least i would i like everything to work it in my car
AntraxL1
Honda Civic (2001 - 2005)
Aug 24, 2014 10:01 AM
bmwpride
Suspension & Brakes
Apr 20, 2008 07:58 PM
irollerblade
Nov 7, 2007 10:04 AM
boostedcvc
Jan 3, 2003 09:45 AM
