Front wheel hubs and lugs
In bad shape? Your lugs or the studs? Do you mean they are stripped on the outside and you can't get them off? You should prolly be a bit more specific
2 of the stud threads are stripped and not sure how to remove. I'm not sure if i have to press out the hub to do it. I tried to tap out with a hammer but they hit the dust plate. Thanks for input. 91 civic HB.
You can get a press tool (big C clamp looking thing) from any auto parts store. Most rent them out and you'll get your money back when you return the tool.
Anyhow, press the old studs out of the hub, and press the new ones in. It's very simple.
MadVladCivic
Dec 3, 2015 06:50 AM
, do i have to buy a hub to repair or is there a way to get them out. thanks for your time!!!
