axle wont come out the spindle, HELPP
Old Jan 30, 2011 | 09:01 AM
wevtech's Avatar
Default axle wont come out the spindle, HELPP
So i started taking the engine out on my friends 99 EK it has a d16 in it blew, its a vergine so EVERYTHING is harder to take out the hoses were stuck to the engine. when i finally got to taking the axels out they wont even move at all, i got the balljoint out and the suspension bolts at the bottom of the strut, and nothing i put WD-40 hit with hammer and NOTHINGG ANYONE HAVE ANY TIPS? OR TRICKS?
Old Jan 30, 2011 | 09:03 AM
Linked's Avatar
Default Re: axle wont come out the spindle, HELPP
a heavier hammer and pb blaster thats been soaking overnight might
the only to getting that axle out is a hammer and force, no tricks
unless you have access to a press
Old Jan 30, 2011 | 09:18 AM
wevtech's Avatar
thank you im a go buy pb blaster... and whats a press?
Old Jan 30, 2011 | 11:50 AM
canadaek's Avatar
air hammer
Old Jan 30, 2011 | 11:56 AM
Linked's Avatar
the machine that shops use to press in bushings/ bearings into tight spots
google for an image, its simply a machine that puts literally tons of force on an object in one direction
Old Jan 30, 2011 | 12:33 PM
thecruzs2007@yahoo.com's Avatar
for the axles use a big flate head srew driver or a ball joint fork and put it between the trans casing and the axle..dont hit it too too hard hit it around the axle and it should pop out.. goodluck
Old Jan 30, 2011 | 02:32 PM
tlarimer's Avatar
He's talking about the spindle side, not the trans side.
OP, make sure you put the axle nut on, but not have the axle protruding beyond the nut, to protect the threads and make sure you don't mushroom the axle end while whaling on with a hammer. I used a 12lb short handled sledge to knock my axles free.
Old Jan 30, 2011 | 02:39 PM
Pabs626's Avatar
torch!
Old Jan 30, 2011 | 02:42 PM
BryanM.'s Avatar
Resident Gearhead
Originally Posted by Pabs626
torch!
Yes! And hit it with the BFH again.
Running into **** like this has made me use C5-A on almost everything.
Old Jan 30, 2011 | 04:09 PM
wevtech's Avatar
lol the biggest hammer i have is 3lb hahah preaty small ill go buy a bigger one i have acces to a press but this kind http://www.norcoind.com/norco/images...rge/78022D.jpg so that wont help il try BFH method then add tourch if that doesnt work lol thanks for the feedback
Old Jan 30, 2011 | 04:51 PM
strategy400's Avatar
A big sledge and piece of 2X4 over the axle end and give it a couple of love bumps. It'll come loose.
Old Feb 2, 2011 | 05:58 PM
luvinlife's Avatar
hit the side of the spindle with the biggest fing hammer you have.
make sure you hit it parellel with the axle and it should pop out after a couple hits. if not... go to the junk yard and get a used knuckle
Old Feb 2, 2011 | 06:46 PM
tales sol's Avatar
leave the bottom ball joint in just until it frees up too so the hub is not moving as you hit it, you only want the shaft to mive not the hub, keeping it solid will give the shaft the full force of your hammer, there is enough movement for the shaft to start moving with the ball joint in anyway!
the timber over the end of the shaft is good too so prevent wrecking the threads!
Old Feb 2, 2011 | 06:53 PM
fonkernuckle's Avatar
I bought a spindle with axle attached cuz the guy could not get the nut off. He had tried wd-40 a "compressor"? any hoo I sprayed some pb blaster, opened up the end where the nut meets the axle with a chisel sprayed with pb blaster waited 1 hour and hit it with an impact wrench and it came off.
Old Feb 2, 2011 | 07:03 PM
D21X's Avatar
to remove a frozen axle nut, i have had to actually drill it off. i would drill the nut so it relieves it's grip around the shaft. be careful not to drill too deep and hit the hub or shaft. when it is close enough, i used a chisel to break the nut loose, then use ur 32mm socket to wrench it off.
before i went this route, my impact gun failed to remove it. also used a breaker bar with a 6ft extension and broke it.....
Old Feb 2, 2011 | 07:28 PM
NotAJDMFanBoy's Avatar
Assuming you got the nut off and the axle is just stuck in the hub, just pound the axle. Soak it well with some penetrating oil. WD-40 is junk, it's fine for squeeky door hinges, but it's not for breaking stuck bolts and stuff.
Old Feb 2, 2011 | 07:30 PM
tales sol's Avatar
i think his problem is the cv joint stuck in the hub itself but maybe the OP should confirm that lol
Old Feb 2, 2011 | 11:07 PM
eghatch9295's Avatar
Stancetard Hate Monger
beat the crap out of it. if it isnt working, lift some weights, repeat.
Old Feb 3, 2011 | 05:10 AM
cd5_2NR's Avatar
whhwha...my axle got stuck onto the transaxle..i had to replace the whole part..!
Old Feb 3, 2011 | 05:19 AM
dem0nk1d's Avatar
Old Feb 3, 2011 | 08:29 AM
Skunk2Joe's Avatar
^FTW^
Old Feb 3, 2011 | 08:33 AM
corvetteking's Avatar
x50 on the BFH... Get urself a 5pm sledge, put ur nut on, and give her he'll...
Old Feb 3, 2011 | 08:44 AM
TwoFaced's Avatar
x3
Old Feb 3, 2011 | 09:49 AM
JDM'dinMD's Avatar
Use a torch then beat the **** out of it. Had to do that last time i took my trans off.
Old Feb 3, 2011 | 10:08 AM
Em1LuiSiR's Avatar
if you dont care about the axle just use a sledge hammer.
