No compression when downshifting
Old Jan 29, 2011 | 03:57 PM
xxliljoxx's Avatar
Default No compression when downshifting
Hi, im new on here and i dont know if i posted at the right place so sorry I bought a 95 civic DX but the motor is a 2000 D16Y7. I ran a compression test and got about 185-190 on all 4 cylinder! My question is : When downshifting i dont feel the compression like it should but my test was 190 on all 4 so could it be that my test was wrong or could it be something else! You know the feeling when you downshift and you feel the car really slowing down? It almost doesnt do it except for third to second gear!
Old Jan 29, 2011 | 04:04 PM
grumblemarc's Avatar
The Grumpiest
Default Re: Question plz help!
Test results sounds rather high. And how do you "feel" compression? That's a new one on me.
Old Jan 29, 2011 | 04:07 PM
tlarimer's Avatar
did you hold the throttle plate at WOT while performing the compression test?
Old Jan 29, 2011 | 04:17 PM
Former User's Avatar
Default Re: No compression when downshifting
Thread titles MUST be subject specific so that members browsing topics can easily understand the tech problem without reading the post:
https://honda-tech.com/forums/showpo...12&postcount=1
Please familiarize yourself with the stickies at the top.
Because you are a new member, I edited the title for you this time.
Old Jan 29, 2011 | 04:29 PM
xxliljoxx's Avatar
Sorry for the title thanks for fixing it! And yes while doing the test i had the gas wide open!! I have a check engine that just appeared so i will jump the connector and get the code!
Old Jan 29, 2011 | 04:37 PM
Do you have an abnormally high idle speed?
Old Jan 29, 2011 | 04:43 PM
xxliljoxx's Avatar
Yes i do i dont have a rpm so i couldnt tell how high it idles but its high thats for sure!!
Old Jan 29, 2011 | 04:44 PM
This would explain why you don't feel "compression" when downshifting. Set your idle speed to spec.
Old Jan 29, 2011 | 05:19 PM
xxliljoxx's Avatar
Is there any guide already made on how to set my idle speed to spec? Cause I have no idea how to do so Thanks
Old Jan 29, 2011 | 05:28 PM
Pull the CEL code first.
Old Jan 29, 2011 | 05:42 PM
xxliljoxx's Avatar
I just went to park my civic behind my block and the CEL is gones O.o it appeared earlier when i floored it and now looks like it disappeared!! Weird!! So i guess i need to find how to set my idle to spec !
Old Jan 29, 2011 | 05:43 PM
What ECU are you using?
Old Jan 30, 2011 | 05:32 AM
xxliljoxx's Avatar
I will go and look today i didnt check yet but is there a guide to put idle speed to spec or not?
Old Jan 30, 2011 | 11:34 AM
xxliljoxx's Avatar
Ok so the ECU in the car is a P2E.
Old Jan 30, 2011 | 02:44 PM
Are any CEL codes thrown?
Any CEL codes? If so, post them.
Also check whether the throttle cable is adjusted too tightly. It should have about 1/2" of free play. Also check whether the throttle body is dirty, which can cause the throttle plate to become stuck partially open.
Old Jan 30, 2011 | 05:08 PM
xxliljoxx's Avatar
No CEL. And i will go and check the throttle body and throttle cable tomorrow its hard at night haha + winter sucks for car repair when you dont have a garage and i dont have a garage
crazyhouse2011
Mar 18, 2013 07:50 PM
92vxjdm
Aug 15, 2008 05:05 AM
crapanese
Oct 30, 2006 10:25 AM
F120man
Oct 20, 2002 03:30 PM
