92 si motor in 95 vx shell
hello everyone i have swapped my 92 civic si motor tranny ecu nd engine harness into my 95 vx shell..the car doesnt seem like its running correctly. im usin the stock p28 ecu that went with that motor and trans. i blow a check engine light for a o2 sensor after it warms up. im goin to change my o2 sensor again tomorrow. if there is n e thing else i have to do to the wiring since the original motor had econimy vtach nd now i have regualr vtech it would be great if someone could helpp
not trying to come off as an a$$hole but its not vtech or vtach its vtec in your case vtec-e which is just the economical version! before you swapped to the z6 did the car have a 5 wire o2 sensor? Cause if it did you have to convert the wire harness to work with a 4 wire o2, sense you already have the p28. convertion consist of swapping a few wires on the o2 disconnect and swapping few at the ecu disconnects. Just google "5 wire 4 wire o2 conversion".
WIRING A 1995 OBD1 B18C1 INTO A 1994 VX CIVIC USING A USDM P72 ECU(this will work for the D16Z6 as well)
LOCATE THE 6 PIN PLUG BELOW ON THE PASS. SIDE VX SHOCK TOWER
The wires are in the following order:
ORG/BLU BLU/GRN WHT/BLK
BLU/YEL WHT/BLU YEL/WHT
REMOVE THE FOLLOWING WIRES FROM THE 6 PIN VX PLUG
ORG/BLU - O2 SENSOR
BLU/YEL - KNOCK SENSOR
LOCATE THE 10 PIN PLUG PICTURED BELOW THAT IS ON THE VX SHOCK TOWER
BRN/BLK EMPTY BLK/RED
ORG WHT ORG/BLU WHT/BLU
BLU/GRN BLU/YEL EMPTY
REMOVE THE RUBBER PLUG FROM THE TWO UNUSED SOCKETS
INSERT THE ORG/BLU (O2 SENSOR) WIRE INTO THE SOCKET BETWEEN THE BRN/BLK WIRE AND THE BLK/RED WIRE. (TOP CENTER SOCKET IN PIC)
INSERT THE BLU/YEL (KNOCK SENSOR) WIRE INTO THE SOCKET NEXT TO THE OTHER BLU/YEL WIRE. (BOTTOM RIGHT SOCKET IN PIC)
NOTE - IF YOU ARE USING A CHIPPED P28 ECU YOU WILL NOT NEED TO WORRY ABOUT WIRING UP THE KNOCK SENSOR
YOUR NEXT STEP IS TO MOVE THE RED WIRE ON YOUR ECU HARNESS FROM A20 TO A17 FOR YOUR SECONDARY RUNNERS FOR YOUR INTAKE MANIFOLD. THEY SHOULD OPERATE AS SEEN HERE .
ALL YOU HAVE LEFT YOU DO IS PLUG IN YOUR ECU AND PLUG THE 3 VX SHOCK TOWER HARNESSES INTO THE GSR MOTOR HARNESSES.
powersk8er92
Sep 15, 2009 11:41 AM
SPOON_BeIgHtEeNsEe
Mar 3, 2008 03:26 AM
