Injector duty cycle too high?
Have a ls, turbo with rc440 injectors, only running on 8lbs boost. gap is fine, wiring for injector harness is getting signal from ecu fine, but i keep losing injectors. I keep hearing from people that my duty cycle is too high on the 440s and that i should step it up. probably going to go 750s but really dont want to re-tune. ANY SUGGESTIONS???
Also, depending on what engine management system you are using you can rescale for the larger injector size and your tune will be "almost" spot on still...
mtber
Engine Management and Tuning
Jun 30, 2015 11:01 AM
