Main Relay Issue?
Old Jan 29, 2011 | 11:24 AM
D12Beast's Avatar
Icon2 Main Relay Issue?
The fuel pump won't prime. I checked the fuses and grounds, they're all good. I checked to see if it was getting any voltage, and it wasn't. I tested the main relay for continuity, its fine. I jumpered the 5 and 7 ports in the main relay plug, still no voltage. I put a multimeter up to the main relay plug and it isn't getting any voltage at all. Any ideas?
Old Jan 29, 2011 | 12:25 PM
Former User's Avatar
Default Re: Main Relay Issue?
What car? Any mods or is it stock?
Old Jan 29, 2011 | 01:34 PM
D12Beast's Avatar
1993 EX. No performance mods.
Old Jan 29, 2011 | 03:36 PM
Double check 15A hood fuse 31 and dash fuse 24. The FAQs stick has diagrams to help locate those fuses if you are unsure.
Old Jan 29, 2011 | 05:11 PM
D12Beast's Avatar
They're fine. Multimeter shows no resistance.
Old Jan 29, 2011 | 05:26 PM
What about voltage?
Old Jan 29, 2011 | 05:47 PM
D12Beast's Avatar
Dash fuse 24 is reading 12V, and fuse 31 is reading none.
Old Jan 29, 2011 | 05:49 PM
There are two metal test tabs at the top of each fuse. Check for voltage to body ground at BOTH tabs individually. Does one of the tabs of installed fuse 31 have voltage?
With the key in ON(II), do both tabs of fuse 24 have voltage?
Old Jan 29, 2011 | 06:00 PM
D12Beast's Avatar
On fuse 31 both tabs have voltage to ground, but when you put a probe on both tabs there is no voltage.
On fuse 24, there is voltage to ground on the tab that is closest to the floor, but none on the one that is closest to the top.
Old Jan 29, 2011 | 06:04 PM
Fuse 31 is fine. Fuse 24 is blown.
Old Jan 29, 2011 | 06:13 PM
D12Beast's Avatar
I feel stupid, but thankful.
You are the man! This car has been sitting around for months now and I no longer have to bum rides :D!
Old Jan 30, 2011 | 11:47 AM
D12Beast's Avatar
Now that its working its been kind of lagging. It takes a while for the fuel pump to kick on once I turn the key ON. Its not much of a problem, more annoying than anything, but sometimes it takes anywhere from 2-5 minutes. Any ideas?
Old Jan 30, 2011 | 02:38 PM
Start by cleaning/sanding and tightening the G101 ground wire attached to the thermostat housing.
Old Jan 31, 2011 | 03:50 AM
D12Beast's Avatar
Done, what next?
Old Jan 31, 2011 | 04:57 AM
Resolder the main relay:
http://techauto.awardspace.com/mainrelay.html
Old Jan 31, 2011 | 02:03 PM
D12Beast's Avatar
OK, got a soldering kit ordered. Anything else I can do until it gets here?
Old Feb 1, 2011 | 04:21 PM
D12Beast's Avatar
Re-soldered it. It seems to have done the trick. It still takes a few seconds, but seconds beats minutes, and its not like I was going to use it as a getaway car any time soon.
jawsiiv
Sep 4, 2010 12:15 PM
ericstambaugh07
Mar 21, 2007 10:27 PM
ef civic
24
Dec 9, 2002 10:01 PM
