integra seats
Old Jan 28, 2011 | 02:55 PM
gnxpro24's Avatar
Default integra seats
has anyone here put integra DA sedan seats in their civic sedan? they are 60/40 so they would latch differently so I want to know.
Old Jan 28, 2011 | 03:13 PM
BiG ChOr!Zo's Avatar
Default Re: integra seats
millions have done it including myself...if using da rails then only 3 will line up where as you will have to spot weld the 4th or drill a new hole...you can also do a seat pan swap...google for instructions...!!!
Old Jan 28, 2011 | 03:26 PM
gnxpro24's Avatar
my bad DA REAR SEATS
Old Jan 28, 2011 | 03:46 PM
tonythetuner®'s Avatar
you need rear seats from a 94 and up integra they use the 50/50 split I tyed the da seat and there a no go not even close...
Old Jan 28, 2011 | 03:48 PM
gnxpro24's Avatar
could I just swap the rear seat pan from the back of the civic seat to the back of the da seat to eliminate the 60/40 and then it would latch in one spot? or even weld or attach the latches from the DA onto my civic. or at the very least weld the 60/40 shut on the seat pan and weld the civic latch on?
Old Jan 28, 2011 | 03:50 PM
You could weld the latch from the integra on to your car and cut the old one off from the civic that would work they still clip where they should at the top of the seat
Old Jan 28, 2011 | 04:37 PM
gnxpro24's Avatar
would it be safer/easier to swap the backrest pans?
Old Jan 28, 2011 | 04:46 PM
Idk never did a seat pan swap on back seats as for being safer if your good at welding or kno some one who is Saftey wouldn't change from stock. But I'm looking for rear seats from a 94 and up integras they bolt right in like stock but you got to modify the lower part of the seat you sit on from wat I have read
Old Jan 28, 2011 | 04:48 PM
gnxpro24's Avatar
well Im going to the junkyard tomorrow because they finally got a red lx with black interior. the cloth in the red sedans was gray tho so I want to get a back seat from a DA integra so it matches my Si seats. I just looked at the latch and really dont want to weld latches on
Old Jan 29, 2011 | 06:35 AM
BlackEM2's Avatar
the 94up teg rear seats.
they back part that latches fit perfect. the bottom part is way to small
da rear seats i couldnt tell you
e13h
Feb 20, 2019 10:54 PM
jsinher3
Welding / Fabrication
Oct 15, 2011 08:59 PM
Got_EF8
Jun 23, 2009 09:56 AM
LoNgHoRn
Jan 18, 2007 01:31 AM
Jay.D.Em!
Apr 3, 2006 03:18 PM
