rhd ef8
How's it going guys I just bought. Rhd ef8 clip and by my surprise I got a sir clip and I can't use the rear subframe from the rhd clip because the my b16 swap mounts won't fot the I would need to get a rhd ef8 sedan rear subframe in order to make my motor mounts work does any body know ere I can get just the rear subframe from a ef8 sedan this is where I got the info new to the rhd conversion any help would be greatly appreciated are there any solid motor mounts for the ef8 sir.
-try to get a clip fom a sohc car or from a model equipped with any ZC. The reason is the dohc equipped hondas DO NOT have provisions on the rear subframe for dual cam AND single cam transmission brackets like our usdm ef's have. They only have the holes in the location for a b-series transmission bracket and you have to use stock crx/civic SiR mounts INCLUDING the actual transmission mount bracket that is welded to the framerail. So if you have a b-series motor and some swap mounts you wont be able to use them. So in other words if you wanted to use a single cam in your new rhd car than you will have to weld the rear mount onto the subframe. The sohc and zc equipped cars have a rear subframe EXACTLY like our usdm cars(minus being rhd of course)and give you The option to use stock sohc usdm mounts or usdm swap mounts. REMEMBER our swap mounts were built around the sohc rear subframe. I was lucky enough to recieve a rear subframe from an ef-sedan.
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/rhd-conversion-how-method-keeps-stock-v-i-n-windshield-2635185/
[B]I NEED HELP I HAVE A EF8 SIR FRONT CLIP CONVERTION WHAT MOUNTS DO I NEED TO USE TO DO A BERIES SW
jdmrhdcrx
12
Feb 15, 2006 08:36 AM
jdmrhdcrx
Feb 14, 2006 09:11 PM
