Can I get some help from the civic crowd pls (measurements)
looking for people that have their shocks off the car and wouldn't mind grabbing a tape measure.
I really would like to find 3 numbers between an 88-91, 92-95, and 96-00.
-Width of shock bushing, or simply the inside space of the fork. (I *think* will be the same for all)
-Fork bolt hole center to the top fork edge Found -> according to http://ef-honda.com/ben/EFhybridsus.php, all forks are the same height
-Fork bolt hole center to the top of the spring perch, ie total height. (not including studs)
Basically, or obviously, I am trying to find a reasonable match. I'd like to use the 8041's. If it can work with a Civic setup then all I will need is a 3 bolt perch.
For 96-00 there would be 2.
One for the regular 96-00 civic and then 1 for the 99-00 Civic Si. They're forks are a little wider and taller.....
The part where the shock goes in, should be the same size for 92-00 civic's.
mikekh10a
Nov 5, 2012 02:14 PM
dc2teg06
Dec 3, 2008 08:53 AM
vlc92189
Jul 29, 2007 02:28 AM
chris_c
12
Dec 10, 2004 12:29 PM
