Crx HF motor rebuild question
Old Jan 27, 2011 | 04:39 PM
vtecn8ive's Avatar
Default Crx HF motor rebuild question
I am in the process of rebuilding a spare d15b6 (HF motor) and I have ran into an issue with one of the cylinders having a slightly larger ridge than the other 3 cylinders (which are within spec).
The problem is that the d15b6 no longer has oversized pistons available
The rods/crank is different than all other USDM d-series motors (smaller/lighter).
The next closest motor (besides an EDM motor) is the 92-95 Civic Cx, which used the same pistons in 92, but 93-95 used pistons identical to 88-91 Crx Dx. The Cx head cast is the same as the Crx HF but has a different rocker assembly and camshaft.
Anybody know if the Crx Dx pistons will work on the Crx HF motor without causing any issues? Any other suggestions?
Old Jan 27, 2011 | 05:21 PM
ef yu's Avatar
Default Re: Crx HF motor rebuild question
HF left ~ DX right
i dont see why they wont work but you might lose compression.
could you use a D15b2 block with HF internals?
Old Jan 27, 2011 | 06:42 PM
radex7's Avatar
Bummer. Can you ****** a nice CX bottom and put your HF head on it?
http://www.crxmpg.com/
Old Jan 27, 2011 | 07:29 PM
vtecn8ive's Avatar
Looks like I will have some measuring to do with the pistons.
vtecn8ive's Avatar
And I currently have a z1 in my 91 Civic wagon.
Old Jan 27, 2011 | 08:48 PM
vg_Ace's Avatar
What do you mean they no longer make pistons for our engines?
When I was rebuilding my D15B6 the problem I ran into is finding the right bearings. Every place that I went to told me they had the right ones, but literally every shop I went to ordered the Dx or Si bearings. And the rings I got from the machine shop were for the Si which are different from the HF.
So finally I just went back to the machine shop and he had like 10 machine parts books and we found the correct bearings and rings. he was very helpful. If you live near Olympia I would advise you to go there.
Old Jan 27, 2011 | 08:56 PM
radex7's Avatar
Or Arias can make them for you....
...for $160 a piece....
Old Jan 27, 2011 | 09:02 PM
vg_Ace's Avatar
I still have my spare D15B6 in my shed. I put a tarp over it and filled the pistons with oil. When my current rebuilt engine finally bites the dust in 2045, maybe I will rebuild it.
Old Jan 27, 2011 | 09:21 PM
vtecn8ive's Avatar
Yeah my current HF has 350,000. The one I'm rebuilding will sit until the current one dies.
Honda no longer carries pistons for the HF motor. I've yet to find an aftermarket supplier. I still need to figure out the bearing issue (I'm aware they are a one of a kind (besides d13 edm motor))
Should be fun ;-)
Old Jan 27, 2011 | 09:32 PM
vg_Ace's Avatar
I believe you when you say Honda no longer carries it. But why exactly to do you need new pistons? Has the block been bored out too much? So stock HF pistons would not seal properly?
Old Jan 27, 2011 | 09:56 PM
vtecn8ive's Avatar
I'll probably need to have it bored do to the top of the cylinder (the ridge) is out of spec. .15". So I am stuck at whether or not I should have it bored.
Old Jan 28, 2011 | 05:24 AM
vg_Ace's Avatar
I know that on Ebay you can buy D15B6s for way cheap. Many Honda guys after they do the first swap on their HFs to something with more power, they just throw the D15b6 away.
Old Jan 28, 2011 | 08:01 AM
vtecn8ive's Avatar
yeah, thats how I got this d15b6 (from a local guy)
Chris Sutton
Transmission & Drivetrain
May 15, 2013 09:19 AM
vtecn8ive
Jan 29, 2011 08:23 AM
adeline
Oct 21, 2007 06:36 PM
freezerburnv2
Sep 4, 2005 04:16 AM
chet
Apr 26, 2003 08:58 AM
