ZC swap running on 2 cylinders??
Old Jan 27, 2011 | 12:59 PM
eazy64's Avatar
Default ZC swap running on 2 cylinders??
okay we just finished swapping my engine zc in to my 89 civic si and we fired it up and its only running on 2 cylinders. what could be the problem??
Old Jan 27, 2011 | 01:02 PM
eazy64's Avatar
Default Re: ZC swap running on 2 cylinders??
ohh yehh and there all getting spark too.
Old Jan 27, 2011 | 02:37 PM
tonythetuner®'s Avatar
Check the wiring for the fuel injectors. Hear is a right up I made
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/diy-dpfi-mpfi-swap-made-easy-2889205/. :Edit: my bad didn't notice you said it was a si
Old Jan 27, 2011 | 02:54 PM
4drEF's Avatar
Keyboard Humorist
First -before you do anything else- do you have compression?
Are the two faulty cylinders getting fuel?
If not, switch injectors out with the two working cylinders and see if the problems changes.
Did you swap any parts over from the Si engine on to the ZC?
Old Jan 27, 2011 | 03:43 PM
eazy64's Avatar
uhmm can i still use check out that wiring?
yehh i switched over my intake and exhaust manifolds and my distributor. and my tansmission and thats pretty much it.
Old Jan 27, 2011 | 03:53 PM
Ya check the wiring. Who knos maybe you pinched a wire or ripped one some where you never kno
Old Jan 27, 2011 | 07:40 PM
BrandonR's Avatar
Is the timing set correctly?
Assuming it's used, have you checked compression?
-Later, BR
Old Jan 27, 2011 | 08:02 PM
KINGVEM^^ED6's Avatar
check ur compression FOO!
Old Jan 28, 2011 | 07:19 PM
stella88's Avatar
Hey did you plug in an injector resistor box? what ECU? stock? or PM6 PR4 PG7? and wiring going to the propper pin-outs?
sounds stupid but it sounds like you may have missed a step, and you are only "Using" two injectors from the orgional 1.5
Im an idiot, so check the obvious! cause I sure as hell didn't!
Old Jan 28, 2011 | 10:01 PM
BrandonR's Avatar
If you read carefully, he said he has an 89 SI. They are already multiport. -Later, BR
Old Jan 29, 2011 | 11:56 AM
eazy64's Avatar
yehh its an SI its already mgfi. okay the compressions good on 3 cylinders its 165 but on cyl. one its 80. and pressure is leaking from cyl. 3 to 4. could that mean a blown head gasket???? and i know the timing aint right yet. havnt timed it.
Old Jan 29, 2011 | 02:52 PM
Jockone's Avatar
Sounds like you have a blown head gasket between 3 and 4.
Old Jan 29, 2011 | 04:08 PM
eazy64's Avatar
what that didnt come out right. cylinder 4 is 80 psi and they told me cyl. 3 leaking to 4. could that be causing the low compression. the blown head gasket????
Old Jan 29, 2011 | 04:48 PM
Yes a blown head gasket will cause low compression
Old Jan 30, 2011 | 03:35 PM
stella88's Avatar
yeah I missed the SI part...sorry
zchatch24
13
Feb 26, 2012 08:47 AM
dturn89
Jun 1, 2010 08:35 AM
EFwithS2000taillights
27
Oct 8, 2005 07:58 PM
VegaS10
Jan 16, 2005 06:07 PM
JapJunkie
Mar 15, 2004 11:14 PM
