B18C GSR Swap suggestions
So I want to do a nice turbo setup. I'm not sure what internals to go with though. I wanna get it for a decent price
Head (GSR Head) I plan to 3 way polish and port and bore valve .5mm
Brian Crower Stage 2 Turbo Cams
AEM Adjustable Cam
Brian Crower Dual Valve Spring
Brian Crower Titanium Retainer
Brian Crower .5mm overbore valve
Ferrea Valve Seals
Ferrea Valve Guide
I got this priced for 1344.00
Is this worth it or is there a better deal somewhere?
Block (JDM B18C GSR 81.5mm) I plan to bore it to 84.5mm and Sleeve it.
What are the best sleeves. And is there a bigger difference between copper and cast iron?
The mods I want are:
CP 84.5mm Low Compression/Turbo Pistons
I want the strongest, cheapest Rods rated at 250hp per rod but I haven't found any resonable.
I have the Crank but I wasn't sure if I should swap it out. Or if it would even make a difference.
Transmission
I have an offer for a S80 B18c GSR LSD welded Hydro tranny for $250
And another for a s4c b16 Newer tranny non lsd hydro
Which should i go with? Preference? Why?
Thanks in advance for advice
AEM Adjustable Cam
Ferrea Valve Seals
Ferrea Valve Guide
Transmission
Should try this in the Forced Induction forum since there isn't anything regarding a swap in this thread. Sounds like a wish list. Especially since this is all just talk seeing as how you have not even listed a simple power goal, what purpose the car will serve and then you talk about cheaping out with the rods. Boost aint cheap if you do it right.
AEM Adjustable Cam
Ferrea Valve Seals
Ferrea Valve Guide
Transmission
AEM Adjustable Cam
Ferrea Valve Seals
Ferrea Valve Guide
Transmission
fully ported b18 head,fresh b18c bare head,aem cam gears,loss motion ass,fresh valve job valves, and
b18sihatch
May 10, 2007 07:46 PM
