B series torque mounts don't fit D series?
I've read numerous posts that say b-series torque mounts don't fit a d-series chassis because of the metal "tab" on the b-series mounts. Has anyone had anyone first experience, is it really not possible to do or just takes some / fabbing washers?
they fit on a 5th gen civic without a problem its the ek that has that
problem. theres piece of metal that gos across the mount and the ek
has a bump on the frame rail between the mounting bolts. you could
shave down the bump with a dremel or keep your d series mounts
So basically on EK, it's possible to run them but requires shaving down the bump on the chassis? Bolt holes still line up and all?
It's a metal tab that's welded on with 2 or 3 spot welds. It can be chiseled off with a little bit of work. Yes, the bolt holes line up and everything.
Momentum
10
Sep 17, 2010 11:01 PM
