B series torque mounts don't fit D series?
I've read numerous posts that say b-series torque mounts don't fit a d-series chassis because of the metal "tab" on the b-series mounts. Has anyone had anyone first experience, is it really not possible to do or just takes some / fabbing washers?
Re: B series torque mounts don't fit D series?
they fit on a 5th gen civic without a problem its the ek that has that
problem. theres piece of metal that gos across the mount and the ek
has a bump on the frame rail between the mounting bolts. you could
shave down the bump with a dremel or keep your d series mounts
It's a metal tab that's welded on with 2 or 3 spot welds. It can be chiseled off with a little bit of work. Yes, the bolt holes line up and everything.
i can confirm they can be used in fact i have them on my car the tab on the bottom of the rail needs to be removed
Momentum
10
09-17-2010 11:01 PM
