F23A1 need valve adjustment
Old Jan 26, 2011 | 02:14 PM
shortlid's Avatar
Icon2 F23A1 need valve adjustment
Ok I have a '99 Ex sedan 5-speed with 165,000 on the clock timing belt has been done at 105k but top end is geting ticking. Does the VTEC F23A1 require valve adjustments?
Old Jan 26, 2011 | 02:44 PM
361 accord's Avatar
Default Re: F23A1 need valve adjustment
lol yes
its not that hard to do it yourself once you get the hang of it-it takes a while, and it'll hurt your back hunching over that far for long since you actually do need to use both hands at the same time for parts, you just gotta compensate for the adjuster moving while you tighten it down
also you'll need the bent feeler gauges, flat ones will bind and be misleading
Old Jan 26, 2011 | 03:52 PM
slowest*em1's Avatar
yes most are due for a valve adjust at 105k
Old Jan 27, 2011 | 03:04 AM
hondamark35's Avatar
yeah, especially on any F-series intake side. it's very tight there with the motor tilted 10-15°.
Old Jan 27, 2011 | 07:08 AM
nus_dogg's Avatar
It's easy. DIY.
Old Jan 27, 2011 | 10:50 AM
swindian1991's Avatar
Ok I Have a 02 accord with the F23A1. just hit 105xxx now last night, i drove through a little creek that runs over a road. it had about 6in of water( prolly not the smartest thing to do) now when i got to the other side my car stalled out. when i went to start it back up it would turnover but not start like i got water in it? Finally got it started, now the motor ticks horribaly. I figured i got water in it so i flushed the oil twice with new filters and 10q of oil. I still cant figure out what it is....... also when i put just a little bit of foot presure on the clutch you can feel the tick in the pedal but when you depress it all the way the ticking gets a tad bit quieter...... Anyone have any ideas what this could be. My thought is that i have a valve stuck or something in the head but idk since i feel it in the clutch...... Help please!!!!!
Old Jan 27, 2011 | 12:57 PM
Bwill9886's Avatar
Please do not thread-jack.
Start your own thread for your problem (doesn't matter if it says you can't, you not supposed to thread-jack either).
You will need to be more specific about your problem as well, FYI. If you can't then we could only throw out suggestions. If you have a trustworthy mechanic, take it to them.
Old Jan 27, 2011 | 06:59 PM
361 accord's Avatar
hehehe that sucks
i'll literally stand on the brakes-***-off-the-seat and come to a dead stop and go around water, if not creep along slower than an old person walks
Old Jan 27, 2011 | 07:30 PM
well sorry that i jacked the thread but i couldnt find anything else to post on considering were all talkin bout accords....idk.... but comes to find out that when i cranked her up i shatered a connecting rod casue it was hydrolocked.....what a b***h!!!!! think ima do a f20 swap!
Old Jan 27, 2011 | 09:57 PM
tpot90's Avatar
HAHA. You do that.
Old Jan 28, 2011 | 06:22 AM
Not a F20 a F20b Bluetop outta the Euro R's..... my bad Forgot to ad that exta letter. That would be crazy stupid to attemp a s2k swap into an accord.....
accordpilot
Apr 12, 2011 09:48 AM
Marcg611
Aug 24, 2008 08:04 AM
kornerk12
Aug 10, 2007 04:45 PM
philosofy1
21
May 19, 2006 07:34 AM
mickey513
Feb 19, 2002 10:50 PM
