SiR or EX brake setup?
Old Jan 26, 2011 | 11:34 AM
gnxpro24's Avatar
Default SiR or EX brake setup?
what all is needed to fit the SiR knuckles to my 89 lx sedan? would the benefits of these knuckles outweigh the simplicity of swapping on the EX knuckles? I can get either knuckles just need to know which are a better setup
Old Jan 26, 2011 | 12:14 PM
GSR CRX's Avatar
Default Re: SiR or EX brake setup?
i believe that the brake caliper on both models are identical. you are probably better off using the EX knuckles due to the SiR knuckle requiring a different outer tie rod. the EX knuckles would be a straight swap. imo for simplicity sake use the EX knuckles that way you wouldnt have to source out SiR outer tie rods.
Old Jan 26, 2011 | 12:15 PM
gnxpro24's Avatar
the other person who had the SiR knuckles on his sedan said the tie rods just need cut
Old Jan 26, 2011 | 12:33 PM
GSR CRX's Avatar
https://honda-tech.com/attachment.ph...1&d=1296077314
only #20 need to be cut if you use the SiR knuckles. no matter how much you adjust the tie rod you will still up with a toe problem. toe in i believe. ??? cutting some of the threads off will allow you to get more adjustment bringing the back of the tire closer to the center of the car putting the tires parallel with the car
Old Jan 26, 2011 | 12:38 PM
GSR CRX's Avatar
come to think of it you might be able to just cut the tie rod but i am unsure how much of the threads will be left inside the tie rod to screw onto the steering rack. it'll be a lot easier replacing an outer tie rod than it would be to replace a rack end (#20) plus its probably cheaper. try it out and keep us updated.
Old Jan 26, 2011 | 04:46 PM
CRX Toad's Avatar
EX or DA. There is big thread in FAQ about it.
Old Jan 26, 2011 | 05:03 PM
gnxpro24's Avatar
what? the SiR knuckles are basically a combo of both of these knuckles.
Old Jan 26, 2011 | 05:04 PM
gnxpro24's Avatar
for SiR knuckles would I use an EX or DA master cylinder and brake booster
Old Jan 27, 2011 | 08:21 AM
GSR CRX's Avatar
how are they a combo of both the EX and DA? don't they use the same sized rotors and caliper combo, 10.25" rotors and 17CL14VN caliper which would technically make them identical besides the curvature and geometry of the knuckles themselves?
Old Jan 27, 2011 | 08:25 AM
GSR CRX's Avatar
i would go with the EX master cylinder since they are both 15/16 and you dont have to swap out the booster. using the DA one will require you to swap out the booster to a DA one also because the mounting tabs are different from one another.
Old Jan 27, 2011 | 11:32 AM
gnxpro24's Avatar
Id be using the corresponding brake booster as well. so EX or DA? also theyre a combo of DA and EX cause they are bulkier than the EX spindles and have DA wheel bearings but have EX components
Old Jan 27, 2011 | 12:25 PM
GSR CRX's Avatar
if your going with EX mc then go with EX bb. if your going with DA mc then go with DA bb
Old Jan 27, 2011 | 12:32 PM
gnxpro24's Avatar
which setup is better the DA or EX
Old Jan 27, 2011 | 12:46 PM
GSR CRX's Avatar
i dont really think it matters. the mc are both the same size.
Old Jan 27, 2011 | 12:52 PM
EFjoe91's Avatar
I have used SiR. Can you even find the parts?
I had trouble getting the SiR Brake booster assembly. Some one in Canada had it it was RDH **** was opposite. I knew it was a good part becasue i could clearly see the Size of the thing compared to the old.
I was "sold" SiR knuckles as well and not sure if thet are SiR becasue of the not that was made about the cutting of tie rods. I dont recall cutting mine?
Maby i have LX being that there is so many. Bit my BOOSTER and all is definatly SiR.
I used Integra DA rear drop ins and had pressed in my own new stuff. all hardware on the Civic stays and any DA or LX would toss. so leave up the stuff thats keeping the current ones on. I had purchased all high performance brake pads and slotted rotors for the rear and have not had any problems yet.
Its hard to find true SiR items. If you can get them go all the way. I did
dannysolis92005
May 9, 2008 10:27 AM
EFstyle
24
Apr 24, 2008 01:24 PM
virginia_dude
Oct 4, 2005 02:06 PM
EL Vap133
Apr 3, 2003 05:04 PM
Francois
11
Jan 7, 2003 05:34 AM
