Need some technicians help! Stumped with cel 16
need help on friends car.
Code 16, car has spark,fuel to rail, no injector spray.
ive checked the main relay, the dizzy, the ecu, ive tried known working ones from my car, no luck, will pay a tech to come over and fix the problem, so if you know anyone that might be able to fix it call me at 562 6466853
im assuming its some sort of wiring problem since all the parts related to that code have been checked and work, ive tested each injector as well and have used a diff set.
well youre getting fuel to the rail, just not injectors, so its either bad injectors or harness that or it could be the rail where the injectors not squirting other than that im out of ideas
you guys do a swap or anything? or is everything original
I've read that entire web site like 3 times, it has a bunch of great info, but everything checks out. We're stumped over here
have had this same problem ona freinds car ended up switching ecu's after everything you tried and something was f'd in the ecu but 9/10 its no signal
T-sohctec
Aug 12, 2003 11:51 AM
