my distributor looks like oils leaking...
Old Jan 25, 2011 | 11:56 AM
blacktibby07's Avatar
Default my distributor looks like oils leaking...
easy fix or no?
Old Jan 25, 2011 | 11:58 AM
EJeff8's Avatar
Default Re: my distributor looks like oils leaking...
Replace distributor O - ring. Done.
Old Jan 25, 2011 | 12:09 PM
ive never pulled distributor off before...
is it just removing bolts and replace or does it have to go back on a certain way?
Old Jan 25, 2011 | 12:10 PM
EJeff8's Avatar
Distributor bolts on one way for the engine to work right. I do not know if you'll have to reset your timing however...
Old Jan 25, 2011 | 12:29 PM
grumblemarc's Avatar
The Grumpiest
Maybe get a whiteout pen and mark the position of the distributor if you're uneasy.
Old Jan 25, 2011 | 01:21 PM
instructor74's Avatar
Where is it leaking from? Is it leaking from around the distributor or inside the distributor you really need to remove the cap to tell if oil is on the inside of the cap = bad distributor seal. oil only on the outside distributor O-ring/ bad valve cover gasket. the distributor only goes in one way it is keyed. I have used a marker to mark where it lines up befor taking off the distributor.
Old Jan 25, 2011 | 01:32 PM
9secondcivic's Avatar
get a perment marker and mark where ur distributor is right now to keep ur correct ignition timing....the take out the drizzy and change the o-ring and that should do it....
Old Feb 5, 2011 | 02:16 PM
brucepick's Avatar
I've been fighting with the two distributor harness connectors. Which one do I press in on and which one do I pull out on the locking tab thing?
Old Feb 5, 2011 | 02:24 PM
94EG8's Avatar
Seagull Management
Pull out on the lack tab and remove the connector off the metal braket, then you can squeeze the on the other tab and you can unplug the distributor.
Old Feb 5, 2011 | 02:40 PM
brucepick's Avatar
OK. I pulled on metal spring tab so the connector comes off the bracket.
Then press on the plastic connector tabs so the connectors come apart? There's a large and a small gray one. They don't want to come apart yet.
Old Feb 5, 2011 | 03:04 PM
94EG8's Avatar
Seagull Management
Both tabs are plastic, the one to remove it from the bracket you have pull out, the plugs wont unplug as long as they are on the bracket.
Old Feb 5, 2011 | 03:12 PM
brucepick's Avatar
Aha. Pull connector off bracket FIRST.
And the harness wires are so short, when I did it once before, I couldn't separate them till after I got the dizzy off the engine. Then I had some slack in the wires to work with.
themiz816
Apr 28, 2013 07:16 PM
tca0bell
Oct 18, 2006 04:16 PM
