Gas door wont close on 91 hatch!
So ive never had a problem with this before. I just got gas and at first the door was hard to open, i had to pull in the lever harder than usual. Assume it was frozen. Now it wont close. is this a common problem? can anyone help me with this? thanks
the fuel door popper is stuck. the cable is sticking. my dx is the same way. i greased it and still does the same thing. only in winter tho. honda doesnt make that cable anymore so you could try a junkyard if you wanna try replacing it. i recently searched ebay and found nothing. unless a cable from an EG would work. i dunno tho
yea you guys are right. the cable is sticking cause of the cold. there must be some water or something trapped in there. i notices the popper releases slowly after a couple hours. damn efs
i had this problem on 2 different ef'ss
check the gas door itself.. that metal thing that hooks onto the popper
check to see if that is somewhat bent.. if so play around bend it till it is good to go
when u pull the lever to release the gas cap it pulls a pin out and the door releases. what happened is i opened it and it got stuck in. so I pulled it back out, bent the metal hook out a little also and so far its fine. probably until I try and open in again lol
Jer'rome
Honda Civic (2001 - 2005)
Feb 12, 2007 03:41 PM
mprznorth
May 1, 2006 06:36 AM
