searched... but no answer to my delima
Old Jan 24, 2011 | 09:14 PM
CRXREFIC's Avatar
Default searched... but no answer to my delima
well i got a clean 89 crx dx shell...
i have a 90 crx hf with a b18 in it... shell is shitty p.o.s
i got to the point of having the b18 into the new car already...
end up dx wiring dont work (that i just found out)
couldnt find any dx engine harness
so i just used my hacked up hf harness from the 90 crx
i got everything in... but theirs like 3 plugs i dont know where it goes.... and when everythings connected... nothing happens... only thing that turns on is the heater blower... wtf?
someone spoon feed me a link to a solution please?
Old Jan 24, 2011 | 09:28 PM
tonythetuner®'s Avatar
Default Re: searched... but no answer to my delima
You need to use the dx engine harness and add the wire you need thats it. the hf harness will not work on a dx. You need to add new wire for the fuel injectors and 2 wires for the dizzy and move some plugs around at the ecu hears a link.https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/diy-dpfi-mpfi-swap-made-easy-2889205/
Old Jan 24, 2011 | 09:30 PM
CRXREFIC's Avatar
im sorry i think i didnt type it out right
i already put the whole dash harness in already from the hf
Old Jan 24, 2011 | 09:44 PM
Well in that case eaither fix up you hacked up hf engine harness or get a new one everything should be plug and play for the most part. Pics off these sensor plugs you don't kno where they go to???
Old Jan 24, 2011 | 09:48 PM
crx_si-r's Avatar
If you rebuild your harness, remember this:
It's NOT the same as an si harness.
The wiring between the hf and si harnesses are different. I can build you a new hf harness if you need it. Pm me if you do.
Old Jan 24, 2011 | 09:51 PM
efjones9's Avatar
do this!
Old Jan 24, 2011 | 09:52 PM
CRXREFIC's Avatar
i dont think i need to rebuild a harness right now...
im just trying to find an answer to this question tho. Can i put my crx hf harness that worked fine from my 90 crx hf to a 89 dx shell?
Old Jan 24, 2011 | 10:00 PM
CRXREFIC's Avatar
oh yea.. my camera doesnt work anymore so i cant take pics till tommorrow...
all the plugs are by the fuse box located inside the car... the fuse box is all connected.. but still no power?
btw is their a pdf online of wiring diagrams?
CRXREFIC
11
Feb 8, 2011 10:13 AM
88EFrex
May 11, 2010 08:51 AM
harmonator84
Nov 11, 2005 07:09 AM
FAST AS
10
Mar 23, 2004 12:17 AM
DOHC_EF
Oct 12, 2003 05:56 PM
