help with mini me!!
Old Jan 24, 2011 | 02:45 PM
slammeda's Avatar
Default help with mini me!!
hey guys, i have a eg that i wanna do a mini in. i got a d15b1 block and a d16z6 head. i have all the stuff that came outta the bay originally(d16z6 stuff ans it has a hole in the block) and a complete d1b motor. so what all am i going to need, parts wise/what will i have to do differently that just puttin the head on the block and puttin it in like i would be a z6, like what will i have to do differnt??
also woul di be able to use a y7 ecu? my harness and p28 ecu got stolen
thanks!
Old Jan 24, 2011 | 02:59 PM
92lxsleeper's Avatar
Default Re: help with mini me!!
basically what you said plus your gonna need the p28 ecu and an adjustable cam gear, or a Y8 cam gear.
you CANNOT run a y7 ecu. 2 reasons, its non vtec, and its OBD-2
but IMHO mini me is a waste of time and money, been there done that wasn't happy.
Old Jan 24, 2011 | 03:20 PM
TaffetaEj6's Avatar
why does he need to run a y8 or adjustable gear? its not like he trying to use a y8 or different cam in the head.
____________________________
ej1 b16a sir 1 gsr trans chipped rpt p28 i/h/e *sold*
ej6 b16a sir 2 ls trans virgin jdm p30 ecu i/h/e -I have a ls tranny...why i am not boosted yet???
Old Jan 24, 2011 | 03:24 PM
because the deck height of the d15 is shorter than the d16. the timing will be off by 1/2 tooth. y8 cam gear is designed to advance the timing on the y8 a little, so it can be used to correct the timing on the minime, same with the adjustable.
Old Jan 24, 2011 | 05:06 PM
HondaPartsHero's Avatar
Technical Hero
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/faq-d15-sohc-vtec-mini-me-massive-write-up-56k-goodbye-554053/
Old Jan 24, 2011 | 06:00 PM
send2artem's Avatar
i did a mini me like 4 months ago i had a y7 and i did a y8 mini me big difference it just all depends on how much you pay for the parts i got everything ecu dizzy spark plugs and wires head cam valve cover intake mani TB literally everything plus he thew in an si tack everything for 250$ and the head only had 120K on it so it was all good and worth it for me
Old Jan 24, 2011 | 06:59 PM
91efbluehatch's Avatar
why downgrade???
Old Jan 24, 2011 | 09:59 PM
send2artem's Avatar
what do you mean downgrade i went from a y7 to a y8
Old Jan 25, 2011 | 04:48 AM
j4s0n1337's Avatar
The adjustable cam gear makes it a lot less frustrating. You can always send your current ecu in to get it chipped, I sent mine to phearable.net and it worked out fine.
You're better off just getting a b18, you'll be glad you did.
Tyler Lemke
13
Feb 26, 2016 01:03 AM
xshafox
May 21, 2015 04:18 PM
AlfieRoach
16
Dec 15, 2010 01:58 AM
chope045
Aug 1, 2010 08:32 AM
mengy007
Jan 12, 2007 11:50 AM
