Ex d series tranny problems :(
So I recently swapped out a dx trans from my 96 civic and put a ex trans in ... So I take it out for a spin and it's running pretty good I start going into higher Rpms and it started making a noise .. So I turn back to go home and I hit a stop I put it first and it doesn't move .. I let go of the clutch and gas while in gear and it doesn't move or stall out . If u know anything to help I'd really appreciate it .. I'm not sure if it's the tranny . I'm really hoping it's Just an axle ..
Check the axles. If anything major happened you'll see it when checking (i.e. diff broke).
If they're good, put it in 5th at a stop, rev it up and let the clutch out. If it doesn't stall, replace the clutch.
If it stalls, pull the trans out to inspect it.
I did the 5th gear thing and it didn't stall out , it's weird because it reads my speed it says I'm goin like 50 but I'm sitting still . And gears went in and out with out pressing the Clutch
Yah it is .. My axle keeps popping out and making a really loud High pitch grinding rattling sound when I put the axle back in and turn on the car ..
