how much tranny fluid will my manual take
hey guys ive searched and got 2, 2.2, 2.5 i cant get the filler bolt out im filling through the speedo sensor and need to know how much to put it.
thanks!
thanks!
Use Honda manual transmission fluid or a comparable lightweight synchromesh manual trans oil. DO NOT use standard gear oil.
The manual was written back in the days of SF and SG engine oil, which contained a healthy dose of ZDDP (1200-1300ppm) as an anti-wear and extreme pressure additive. Modern SM engine oil contains much lower levels of phosphorus (less than 600ppm) for preservation of emissions equipment, but this results in poor shift quality when used in a Honda transmission. Honda's current MTF formula (~2006 and newer) is a light 0W-20 equivalent and has a high ZDDP content (around 1500ppm) among other modifiers to improve shift feel. Standard gear oil uses a lot of sulfur and/or boron, which can sometimes cause problems with the brass synchros and some of the bearings in the trans; Honda MTF has no sulfur and no boron at all.
Cliffs: Engine oil results in clunky shifts. Honda MTF shifts much smoother.
Kaliona
38
Aug 3, 2009 05:53 PM
