07 civic horn problem
Check you fuse diagram in the owners manual, locate the proper fuse box and the correct fuse.
Check the fuse if it's blown put one of the spares located in the box and you are done.
Check for power at the horn plug when the horn button is pressed. If you have power, the horn itself is bad, which is pretty common.
If you don't have power, start looking for a fuse/relay/wiring problem.
kturner2007
12
Jan 9, 2007 10:03 AM
Rhythm Racer
11
Jun 27, 2003 10:46 AM
