Si Knuckle on my std.
Old Jan 23, 2011 | 07:06 AM
TougeCoupe's Avatar
Default Si Knuckle on my std.
I have some si knuckles laying around can i go ahead and put them on my std hatch will they fit without a problem.
Old Jan 23, 2011 | 07:12 AM
maritime_ef's Avatar
Default Re: Si Knuckle on my std.
If its not the 4 speed standard then your fine... everything will bolt right up... if it is the 4 speed then you need to get 5 speed axels too
Old Jan 23, 2011 | 07:14 AM
TougeCoupe's Avatar
well thats sucks its 4 speed so i take it the 5 speed axles will slide into the 4 speed tranny with no problem
Old Jan 23, 2011 | 08:16 AM
pimpwagon's Avatar
if its a 4spd manual, isnt that an std model? i thought those were not the same spline count as the dx, si, and ex...
Old Jan 23, 2011 | 09:34 AM
TougeCoupe's Avatar
yeah it is a 4 speed so im thinking the five speed axle are gonna work with my tranny.
Old Jan 23, 2011 | 09:46 AM
will fit in the transmission fine, hubs are just different... I went through this with my car.... Ran an si transmission with 4 speed axels for 3 years until i found some si knuckles and 5 speed axels for a good deal
Old Jan 23, 2011 | 09:53 AM
tonythetuner®'s Avatar
Only the hub splines are diffrent not the splines where the axle go into the tranny
Old Jan 23, 2011 | 11:40 AM
jlk16188's Avatar
ok to sum up everyone's post and clarify for you.
Swap the si hubs and the si axles. Only the hub side of the axles are different. The SI axles will fit right into your 4 speed tranny and work with the si hubs
civicbizz253
Aug 30, 2017 04:22 AM
hatchlvr
May 25, 2006 01:01 PM
Hondaisok
16
Feb 15, 2006 11:03 AM
92civalac
10
Jan 14, 2005 10:06 AM
RATEDR
Feb 13, 2002 08:14 AM
