dyno help on .48 and .63 ar turbo housings on stock itr
Old Jan 22, 2011 | 10:25 PM
racebum's Avatar
Default dyno help on .48 and .63 ar turbo housings on stock itr
curious if anyone has or knows where i could find dynos on a stock itr running either
http://www.spoolinperformance.com/ga...trim-p-30.html
or
http://www.spoolinperformance.com/ga...er60-p-33.html
i'm leaning on the super 60 mainly due to that smaller housing on fast spool time. what i'm mostly curious about is where both create peak boost. the first option is capable of a good deal more flow, just not sure it's needed for 280whp
Old Jan 26, 2011 | 07:41 AM
JDM_EH2's Avatar
Default Re: dyno help on .48 and .63 ar turbo housings on stock itr
Check www.evans-tuning.com
Old Jan 26, 2011 | 12:37 PM
racebum's Avatar
have it mostly figured. googled the living hell out of R dynos and what's going on. the .63 in 99 out of 100 cases is the better choice, now it just comes down to a 50 or 57 trim
Old Jan 26, 2011 | 05:02 PM
FULLYBUILT2.0's Avatar
Get a 63. It will spool just as fast and give you more power to play with. 48 is just too small. If I was looking to get 280whp I would of went with a super charger with some bolt on. Pulls harder with no lag but like people say. When you have boost, you just want more and that's where a SC lags. So everyone goes turbo
Old Jan 26, 2011 | 05:25 PM
Garrett's Avatar
I almost always recommend 0.82AR and Gt3582R
full boost ~4000 rpm, low pressure, high power,
racebum's Avatar
yea a 63 is a given. the debate now is using a 57 trim or ordering the 50 trim, both with the stage 3 wheel. both spoolin and shodan have suggested the 50 trim with the stage 3 wheel as being a good match for a stock itr looking for 300whp. you don't need a lot of pressure and it spools fast
http://www.dezod.com/pd-garrett-t3t0...ocharger60.cfm
http://www.dezod.com/pd-garrett-t3t0...-discharge.cfm
it's one of these two and the more i look and research the more it seems the stage 3 50 trim with the .63a/r is almost a perfect match to a stock itr engine
Old Jan 28, 2011 | 05:24 PM
gosu08's Avatar
I ran that exact same turbo (Garrett 57 trim) on my stock motor. Get the .63 AR.
The .48 will choke up and you wont make good power at all up top especially because we are high revving motors
Old Jan 28, 2011 | 06:10 PM
justin.parker's Avatar
If you are ever going to think of more power, I would suggest getting the 57 trim. If you honestly believe 300 is your goal and you will stick to it, the 50 is more than enough turbo.
My .02 is the 57, spool times are not enough to notice and the 57 has more potential.
gringotegra
Jul 8, 2010 12:11 AM
98-DC4
Jan 10, 2008 12:53 PM
Pompiuses
Feb 3, 2007 06:27 PM
WEldin4fun
May 12, 2005 07:09 AM
