Built + Boosted Z6 Motor + Tranny Etc. - 373whp 315tq!! SUPER LOW MILES!!
Up for sale is my complete built D16z6 motor and tranny. It has YCP Vitara 8.5:1 pistons, Crower pro-billet rods, ACL race bearings, ARP head studs, Cometic MLS head gasket, Precision SC50 turbo, AFI ramhorn exhaust manifold and 3" mandrel downpipe, Tial 38mm wastegate, Turbonetics Raptor BOV, Skunk 2 intake manifold, Spearco FMIC, 2.5" mandrel bent IC piping, RC 750cc injectors, B&M billet FPR and gauge, P28 ECU chipped and tuned with Crome, Turbo XS dual stage MBC, Competition Clutch 6 puck clutch, 'Mugen' valve cover, K&N cover breather, Autometer carbon 30psi boost and air/fuel a-pillar gauges, Prothane motor mounts, MSD plug wires and distributor cap, etc. The motor has less then 900 miles on it. I broke it in for 500 miles then went to the dyno, no track passes, just street driving. Every bearing, seal, gasket, water pump, oil pump, pickup, timing belt, etc. was replaced when I assembled the motor, everything was brand new, im very very meticulous as you will see by the pics. The motor put down 373whp and 315ft/lbs of torque at 23 psi on the dyno, it runs fantastic, pulls like a freight train! The tranny has 84k original miles on it, no grinds what so ever, shifts great. I guarentee you wont be dissappointed, everything is spotless and works 100%. Also included is the wiring harness, axle's, mounts, any everything else for a complete swap. $3500. Here are some pics............
very impressive! if you were willing to part the motor i think we could work out a deal on the short block. already have a fully built head.
Yeah I kind of figured that, going to try to sell it as a whole first but more then likely im going to have to part it.
Hoping I am gonna make around there with the same build pretty much you have . I have a stock head everything else is the same. Just picked up a ramhorn so see how much more flow I can get ...
Was your power put down on pump or racegas?
es01 is correct, I made a mistake in the original post, they are vitara's. I had SRP's in a previous setup. My bad.
Racegas. The tuner wanted to push it over 400whp but i was content with 373whp.
I have most everything right now, what are you interested in?
