i need help asap 94 h22aswap accord
Old Jan 21, 2011 | 04:24 PM
1994accordh22a's Avatar
Icon6 i need help asap 94 h22aswap accord
I HAVE A SWAPED 94 ACCORD THROWING A CEL AN ITS VERY SLUGISH AND NO VTEC ITS THROWING CODES 4,10,20,6 AN ITS VERY HARD TO START AFTER IT SETS A FEW HOURS ANY ANSWERS ON THIS was told it was my ecu causeing all theses codes wat ecu should i be running
Old Jan 21, 2011 | 06:06 PM
GhostAccord's Avatar
Default Re: i need help asap 94 h22aswap accord
OBD1 P13
Old Jan 21, 2011 | 06:25 PM
nus_dogg's Avatar
I guess he did two same threads eh?
Here are the codes you listed:
-Code 4 - Crank Position(CKP) Sensor
-Code 6 - Engine coolant temperature
-Code 10 - Intake air temperature sensor
-Code 20 - Electric load detector
I'm not sure about code 20 as thats the first time I've heard of this. I'd check the connection at the sensors on code 4, 6, and 10 to see if they're connected to the sensors and not loose and also use a Digital Multi Meter to test the circuit and if it tested out good then OHM test the sensors and compare those numbers you got with the given specs. It's either the sensors itself, wiring, or PCM that is cause those codes to come on. If indirectly test the sensors(load), the whole circuit should be good and only thing left to check is the sensors. Hope you get where I'm trying to go with this.
I'd search up on the Resistance of each sensors to see what they are so you know if it's under or over the given spec. Good Luck!
Old Jan 21, 2011 | 07:01 PM
bruno8747's Avatar
What ECU are you currently running with the swap?
Old Jan 22, 2011 | 05:08 AM
accordracing91's Avatar
I'm guessing the ECU is ****ed. Throwing that many codes is for 2 reasons, either the wiring wasn't properly done or the ECU is dead.
Go with the P13.
Old Jan 22, 2011 | 12:28 PM
nus_dogg's Avatar
Go with the P13.
Or the sensor is bad.
Old Jan 23, 2011 | 01:39 PM
now i am throwing 6 and 10 ecu codes and when i start my car i throw 14 which iacv my fan wasnt kicking on so i wired it to were i turn the key on and the fan comes on. Why am i still throwing 6?
Old Jan 23, 2011 | 04:40 PM
nus_dogg's Avatar
Did you OHM test the ECT sensor?
coolrahool
Feb 29, 2020 10:25 AM
Vette117
May 7, 2018 05:11 AM
Loughf
Oct 22, 2014 06:24 AM
xide_12
Mar 29, 2011 10:56 AM
1994accordh22a
Jan 21, 2011 05:52 PM
