Mpfi stuttering problems
Old Jan 20, 2011 | 10:03 PM
spens 91 Ef's Avatar
Default Mpfi stuttering problems
I recently got my car started and running after 4 months of sitting, it's a d15b2 with mpfi and a 272 cam. It's running but it likes to bog down at low rpms but when it gets up past 4 it seems pretty normal, I need help trying to figure out this timing has been checked and rechecked. Sounds to me like a fuel problem?
Old Jan 20, 2011 | 10:12 PM
tonythetuner®'s Avatar
Default Re: Mpfi stuttering problems
Any cel?? Was the car converted to mpfi??? You got me lost lol a d15b2 is not mpfi unless you swapped out the intake manifold...
Old Jan 20, 2011 | 10:23 PM
Exactly that's why I said d15b2 because it was converted to mpfi I did it myself all the soldering and wiring, no cels. Is there a diagram for the big dizzy plug showing which color wire goes where?
Old Jan 20, 2011 | 11:20 PM
Navy_Kyle's Avatar
spark plugs fouled
fuel injection system faulty
fuel filter clogged
incorrect timing
intake manifold leak
thats right out of the repair manual, id check that stuff and see what happens cuz my d16y8 in my ef does the same thing and its converted to obd1 but my timing is off by 180degrees lmfao
Old Jan 22, 2011 | 09:20 AM
i had the 2 cps wires that you had to run to the dizzy switched running alot better now, but wont idle worth a crap
waynesumner
36
Dec 6, 2013 05:57 PM
EF2SLOW
May 10, 2012 05:52 PM
swirve1
Apr 20, 2011 03:32 PM
"goose"jay
Feb 23, 2011 06:53 AM
dohc4life
12
Jan 11, 2010 01:35 PM
