97 acura cl trans issue
Old Jan 19, 2011 | 07:41 PM
upgrayedd's Avatar
Default 97 acura cl trans issue
anyways heres my problem,
i have a 97 acura CL v6, the trans was bad, so i got a transmission out of a 99 accord, and everything bolted up right, and it runs and drives fine, except one plug, and it goes to a sensor on the side of the transmission, and theres no place to put my speed sensor, can anyone tell me what this thing on the side of the trans is, and a way to wire my speed sensor to it?
or possibly if you have all data, post a photo of which wires are for what. thanks
Old Jan 19, 2011 | 08:29 PM
92civlude's Avatar
Default Re: 97 acura cl trans issue
Some of the older transmissions have a plate and 10mm bolt covering the area where the VSS "should" go. Check it out.
Old Jan 19, 2011 | 08:38 PM
upgrayedd's Avatar
the trans came out of a 99 accord v6. theyre both j30a1 cars. i figured the transmissions would be the same.
it has a hole where the vss should be, but its not a hole. lol i thoiught it was filled with ice, but its not, its solid metal.. i dont understand.,
Old Jan 19, 2011 | 08:52 PM
92civlude's Avatar
SOME of the older transmissions have a plate
Bummer. You werent lucky on this one.
Old Jan 19, 2011 | 08:56 PM
upgrayedd's Avatar
well, theres gotta be a sensor that reads the speed somewhere on this thing, probably on the 10 wire male plug i done have a female for.
im just asking if anyone knows which wires do what on the "TEC" sensor. that way i can wire up my vss to it.
Old Jan 19, 2011 | 09:18 PM
upgrayedd's Avatar
ill just go color to color and see if that works =\
Old Jan 20, 2011 | 08:21 AM
92civlude's Avatar
On the transmissions without a VSS. The ECM interprets speed from the countershaft speed sensor. Hope that helps you.
Old Jan 20, 2011 | 08:27 AM
upgrayedd's Avatar
it does.. kind of.
now i know that the thing on the side of the transmission is a speed sensor.
ill try to hard wire it into my harness
Dirtyunderpants
Sep 14, 2018 08:41 PM
Alwayscali
Sep 29, 2012 04:29 AM
upgrayedd
Jan 15, 2011 09:16 PM
