Rotating my tires and found this, wtf?
Old Sep 24, 2002 | 12:34 PM
skafia's Avatar
25 Year Member
Default Rotating my tires and found this, wtf?
Does this look safe to anyone? What happened?
Old Sep 24, 2002 | 12:38 PM
JaeOne3345's Avatar
Default Re: Rotating my tires and found this, wtf? (skafia)
what exactly did u find..i see the normal rusted hub from normal wear and tear..
and i see the normal axle nut that is smashed where it should be in that slot.
Old Sep 24, 2002 | 12:39 PM
skafia's Avatar
25 Year Member
Default Re: Rotating my tires and found this, wtf? (JaeOne3345)
Ok, that's what I was referring to. The axle nut is supposed to be smashed into that little slot?
Rguy's Avatar
Voted Best Looking GDD Poster
25 Year Member
Community Builder
Community Influencer
Active Streak: 60 Days
yes, dont know why u have two though.
Old Sep 24, 2002 | 12:43 PM
JeffS's Avatar
Default Re: Rotating my tires and found this, wtf? (Rguy)
Looks like someone incorrectly re-used the nut after taking it off.
Old Sep 24, 2002 | 12:44 PM
Jimmy L's Avatar
It looks like the axle has been removed and was not replaced. Did you pull the axle for any reason? I had new axle nuts when I did my swap but I've heard you can get by re-using the axle nut once, no more than that.
Old Sep 24, 2002 | 12:49 PM
skafia's Avatar
25 Year Member
Default Re: Rotating my tires and found this, wtf? (Jimmy L)
Well... my clutch, tranny casing was replaced. Is it necessary to remove the axles? Should I do something about this?
But you know what's funny, when I'm driving fast and I stop hard... something in the front suspension makes a loud "CLUNK" noise. Like metal hitting metal, I'm wondering if this is related, think it's time to take it to Acura for a road test?
Old Sep 24, 2002 | 12:52 PM
uNF$@#!'s Avatar
motor mounts ok?
sneakychaos's Avatar
Yes, usually they should remove the axles when replacing the clutch as they have to drop the transmission.
Old Sep 24, 2002 | 12:53 PM
skafia's Avatar
25 Year Member
Default Re: Rotating my tires and found this, wtf? (Soup ****)
dunno, how can you tell?
Old Sep 24, 2002 | 01:03 PM
reefer_bob's Avatar
Default Re: Rotating my tires and found this, wtf? (JeffS)
Are you supposed to replace this nut when ever you take it off?
Old Sep 24, 2002 | 01:09 PM
rudeS2k's Avatar
Default Re: Rotating my tires and found this, wtf? (reefer_bob)
look into thoroughly..
Old Sep 24, 2002 | 01:10 PM
Bbasso's Avatar
Default Re: Rotating my tires and found this, wtf? (trooth)
"Yes, usually they should remove the axles when replacing the clutch as they have to drop the transmission."
but not in that manor, just remove the cotter pin and then king nut and separate the lower from the hub. No need to take that nut off for pulling a tranny
sackdz's Avatar
I'm sure everything is fine and that your clunking sound is unrelated. For piece of mind retorque the axle nut to 140ftlbs. It's a 32mm socket.
Old Sep 24, 2002 | 01:12 PM
B2FiNiTY's Avatar
Clunking sound coule be a lot of things...
Old Sep 24, 2002 | 01:16 PM
Dave-ROR's Avatar
Default Re: Rotating my tires and found this, wtf? (Bbasso)
[QUOTEbut not in that manor, just remove the cotter pin and then king nut and separate the lower from the hub. No need to take that nut off for pulling a tranny[/QUOTE]
oh, and I reuse axle nuts all the time.
Old Sep 24, 2002 | 01:17 PM
PatrickGSR94's Avatar
Community Builder
I removed my axle when I swapped out my alternator, but I did not replace the axle nut. I just torqued to 140 and re-staked the nut.
Old Sep 24, 2002 | 01:24 PM
chad's Avatar
Moderator
Default Re: Rotating my tires and found this, wtf? (PatrickGSR94)
you must remove drivers axel to get alternator out.....on cars with Bseries engines....i have tried every possible thing....is there any way to remove alt without taking out axel??
Old Sep 24, 2002 | 02:17 PM
yoshi234's Avatar
I shoot brides
tranny can be removed w/ out having to remove the axle nut or even the axle completely
Old Sep 24, 2002 | 03:43 PM
Johnny62's Avatar
New User
Hey, what's up skafia?
I wouldn't sweat it at all. Like everyone has been saying, it looks like the nut was removed once and then put back on and dinked at the slot to keep it from backing off. It is recommended that this nut be be replaced if it is ever removed but as long as it is torqued to the correct specs it should be fine.
I've got a torque wrench and the correct socket. Hit me up if you want to verify that you are at 140 lb ft.
- J
Old Sep 24, 2002 | 04:40 PM
skafia's Avatar
25 Year Member
Default Re: Rotating my tires and found this, wtf? (Johnny62)
hehe what up John. Alright man, maybe we'll do that, just to be on the safe side, you never know. One day the power of the R might break my axles or somethin'.
Old Sep 25, 2002 | 10:13 AM
Hooch'n's Avatar
I agree looks like someone took it off and then put it back on....mmmmmm.
Old Sep 25, 2002 | 02:27 PM
b18c-rDC2's Avatar
Default Re: Rotating my tires and found this, wtf? (Hooch at 8400-RPM)
all of them have at least one crimp....but i suggest you replace them each time for peace of mind!
Old Sep 25, 2002 | 02:46 PM
Paste's Avatar
Loved
Default Re: Rotating my tires and found this, wtf? (b18c-rDC2)
yeah mines like that too
Old Sep 25, 2002 | 11:04 PM
skafia's Avatar
25 Year Member
Default Re: Rotating my tires and found this, wtf? (paste)
oh alright, thanks for all the info guys!
PhantomPharter
20
Apr 4, 2012 03:14 PM
flaxx0r
28
Dec 29, 2008 07:15 AM
LS94tegra
Apr 19, 2008 11:59 AM
dynamo
13
Nov 14, 2005 08:22 PM
JDM96SpecCTR
13
Dec 6, 2004 01:34 PM
