Transmission & Drivetrain Gearboxes, Differentials, Clutches
H2B NOT GOING INTO GEAR !!
Old Jan 19, 2011 | 10:01 AM
juan3023's Avatar
Default H2B NOT GOING INTO GEAR !!
Well here is the deal I am having issues with my h2b cr-x not going into gear once the car is ON can some h2bers on here give me some advice on what could the problem be I am running a ctr tranny (hydraulic transmission) with a qsd kit I would really appreciate your help
Thank you
Old Jan 19, 2011 | 01:45 PM
Green Crack's Avatar
Default Re: H2B NOT GOING INTO GEAR !!
Was tranny was good before you put it on?
Old Jan 19, 2011 | 05:24 PM
H22EKHATCH's Avatar
have u adjusted the clutch cable where it attaches to your hydro/man. conversion kit.......or did you convert to a full hydro?
Old Jan 21, 2011 | 11:34 AM
juan3023's Avatar
I bought it from a local member on our honda forums
Old Jan 21, 2011 | 11:35 AM
juan3023's Avatar
I did the full hydro
Old Jan 21, 2011 | 11:39 AM
speedooo's Avatar
Does it go into gear with the car off?
Old Feb 3, 2011 | 01:14 PM
juan3023's Avatar
yes sir
Old Feb 3, 2011 | 01:43 PM
95 Integra gsr's Avatar
with the car off put it in gear. press down on the clutch and start the car. dose that car want to roll forward like its in gear?
Old Feb 8, 2011 | 09:33 PM
93h2beg's Avatar
sounds like your clutch is not disenguaging. did you properly bleed the clutch??? have a friend push the clutch pedal and watch to see if the fork moves
clekers
Aug 30, 2009 10:59 PM
charmin1213
Sep 19, 2008 10:32 PM
Snailed EF
16
Oct 17, 2006 03:23 PM
illestrolla247
Sep 19, 2004 08:27 PM
oemDC2
Apr 26, 2004 05:10 PM
