best/safest cam for my build B16
Old Jan 18, 2011 | 09:51 AM
nels00n's Avatar
Default best/safest cam for my build poormansR
new thread..
Old Jan 18, 2011 | 10:13 AM
h0ndab0yb3b0's Avatar
Default Re: best/safest cam for my build B16
go big lol...just go toda vtec killers lol
Old Jan 18, 2011 | 10:26 AM
nels00n's Avatar
Old Jan 18, 2011 | 10:27 AM
Mr. EG's Avatar
What an intelligent response. OP I doubt you will make 180WHP out of this build, but you will come close. I presonally would go with Pro 1's after reading a few articles. Here is the first one http://www.skunk2.com/editorial/IMPO..._1006_PP_1.pdf, and the second http://www.skunk2.com/editorial/TURBO_PROFILE_0804.pdf.
Old Jan 18, 2011 | 10:28 AM
nels00n's Avatar
Old Jan 18, 2011 | 10:35 AM
lol jaja..it was a joke thats my cousin (the op)lol
Old Jan 18, 2011 | 10:42 AM
Mr. EG's Avatar
I know what motor you refering to and no I doubt you will make 180WHP with higher compression and those cams. You will come close though. With some port work and a nicer header (not Ebay crap) and a really good tuner you would be more likely to reach your goal.
Here are a couple graph's I found:
http://www.jdmuniverse.com/forums/na...ults-good.html
https://honda-tech.com/forums/all-motor-naturally-aspirated-44/ll-w-lls-b16-dyno-results-stock-bore-stroke-oem-honda-200-whp-1201433/
https://honda-tech.com/forums/all-motor-naturally-aspirated-44/can-we-get-official-b16-all-motor-dyno-thread-2466663/
Old Jan 18, 2011 | 10:52 AM
nels00n's Avatar
Old Jan 18, 2011 | 11:14 AM
Mr. EG's Avatar
I miss- understood your first post. You are planning on using ITR pistons in a USDM Gs-R block and putting your B16 head on it? If that is the case you should make right around 180 whp.
Old Jan 18, 2011 | 01:23 PM
nels00n's Avatar
Old Jan 18, 2011 | 01:28 PM
DDTECH's Avatar
get a better tranny, but the pro1's should do nicely for you.
Old Jan 18, 2011 | 01:52 PM
00Red_SiR's Avatar
All Motor Mentor
Out of all those cams listed, I would have picked ITR cams first, Skunk2 stage 2 tuner cams next and pro 1 cams a distant last as far as "best" cams that will work well on a 1.6 -1.8 build.
Old Jan 18, 2011 | 02:02 PM
N/A's Avatar
N/A
Purpose Built
Itr cams
Old Jan 18, 2011 | 02:04 PM
DDTECH's Avatar
s2s2's would probably really do really well on here
i still stick by getting a better tranny then a ls..
Old Jan 18, 2011 | 02:16 PM
its a ls casing with b16 gears... casing cracks on the b16 so swapped out casing the internals are all b16
Old Jan 18, 2011 | 02:58 PM
DDTECH's Avatar
didn't know that.. your good to go
Old Jan 18, 2011 | 04:00 PM
nels00n's Avatar
Old Jan 18, 2011 | 04:16 PM
tripleXccc's Avatar
What about a Bisimoto cam.. i have one in my car and i love it.. best part ive put in my car.. just a suggestion
Old Jan 18, 2011 | 04:21 PM
nels00n's Avatar
Old Jan 18, 2011 | 04:24 PM
tripleXccc's Avatar
Bisimoto.com/store
gives you all the cams u need depending on the specs and power out put your looking to get out of for your car
Old Jan 18, 2011 | 04:49 PM
nels00n's Avatar
Old Jan 18, 2011 | 05:04 PM
00Red_SiR's Avatar
All Motor Mentor
Originally Posted by nels00n
so on my build I sould keep it OE and just get JDM ITR cams? those will be better than pro1s or tunerSTG2s?
Well the thing is that you want to use the cams on both builds potentially. ITR would be excellent on the b16a, and decent on the B18c but the other two cams you mentioned will make more power. The Skunk tuner 2 cams will work ok on the B16a and work really well on the B18c. The pro 1 cams will be a little large on the 1.6 and will be right at home and make the most power on the 1.8L but not much more than the s2s2's in VTEC. The pro's will also be a little harder to tune as well than the other two types.
Old Jan 18, 2011 | 05:09 PM
nels00n's Avatar
Old Jan 18, 2011 | 05:11 PM
00Red_SiR's Avatar
All Motor Mentor
You could but I think the S2S2's would still beat that cam setup in your B16a so I would personally pick them as your best overall choice for both engines.
Old Jan 18, 2011 | 05:14 PM
nels00n's Avatar
