rsx wont start help asap.
Old Jan 17, 2011 | 08:01 PM
SOHConthis's Avatar
Default rsx wont start help asap.
alright heres the deal i bought an 02 rsx type s with a blown motor then later got an 02 type s swap, motor, harness,ecu etc.now motor is in and everything is pluged and so on and so on problem is it dnt start. however it does get fuel and turns over but there is no spark iv checked and double checked fuses all good. im not all that familiar with k's dnt know wat it could be anyone have any input or suggestions.
Old Jan 17, 2011 | 09:20 PM
Type-Spaz's Avatar
DC5/EP3 MOD :)
Default Re: rsx wont start help asap.
was the wiring harness modified at all? Your manifold ground (the main one between your injectors) is good?
Old Jan 17, 2011 | 09:42 PM
SOHConthis's Avatar
no mods to the harness. the ground wire is hood the a bolt on the manifold.
Old Jan 19, 2011 | 08:22 PM
SOHConthis's Avatar
anyone else have any input.
Old Jan 20, 2011 | 10:37 AM
thrty8street's Avatar
is the timing correct?
Old Jan 22, 2011 | 07:22 AM
SOHConthis's Avatar
timing is a lil off. but will that not make it turn on.
Old Jan 22, 2011 | 08:28 AM
1LDucatiBeater's Avatar
my guess would be a bad cam or crank sensor. the ecu needs to see cam and crank reference to start the injection/spark sequence. i would look into those first
huntkirby
Apr 13, 2018 04:31 PM
mikej33
Dec 26, 2016 02:46 PM
Importracer_001
Aug 5, 2014 06:40 PM
tylerstephen11
11
Nov 15, 2011 01:09 AM
tblango
Oct 3, 2005 08:30 PM
